Spindles
Old Mar 30, 2011 | 10:15 PM
clean92rs's Avatar
Car: 92 camaro RS
Engine: Vortec 355,262/268 cam,670holley
Transmission: 5speed
Spindles
Has any one ever replaced the spindles on these 3rd gens? I have a 92 that I'm about to replace both spindles and just looking for a little advice to make this go a little smoother. Thanks
Old Mar 31, 2011 | 08:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Spindles
why are you replacing them? they dont usually do bad? are the damaged?
i've had mine off a few dozen times, its not difficult. Just be sure to support the a-arm when you remove the strut or the spring will come flying out.
Old Mar 31, 2011 | 09:00 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Spindles
Its pretty easy. Basically you take the caliper off, the rotor off, then put a jack under the control arm, then pop the ball joint out of the spindle, then unbolt the two bolts that hold it to the strut.
I like to take an old seat belt, or even rope, anything and tie it through the spring and out the bottom of the control arm. This is just to try to capture the sping should it fly out.
Old Apr 2, 2011 | 08:59 PM
clean92rs's Avatar
Car: 92 camaro RS
Re: Spindles
the right side caliper bracket holes are stripped out i didnt know this till after i bought it and took it off. built how did you wire your gauges i wanna do the same thing but i dont want it to looked hacked up. thanks again for the help guys
Old Apr 3, 2011 | 05:06 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Spindles
you have a PM
Old Apr 3, 2011 | 05:13 PM
clean92rs's Avatar
Car: 92 camaro RS
Re: Spindles
ok fueled ill let you know when i get them done we can work something out. if your needing some new spindles there is a guy on ebay who has tons thats where i got my new ones from they are beautiful and cheaply priced.
Ghettobird52
Apr 21, 2020 08:44 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
jdperformance
Sep 16, 2015 11:55 AM
rb85TA
26
Sep 14, 2015 10:29 PM
