Steering Box rebuilt @ Lee Man.
Old Apr 15, 2011 | 10:46 AM
houstonvett's Avatar
I just got back a steering box from Tom and Gayle out @ Lee Man. in Ca. Tom builds lots of race boxes for big name teams and does great work. This box is setup at a 9:1 ratio with corresponding steering valve and should be very tight. Spohn coil over setup with tubular control arms and tubular K frame should make this 85 Camaro handle a lot better then it did out of the factory. Tom also re-built the PS pump for higher volume and added a nipple to the side of the pump for the return line from the HB brake setup. Lee Man. still does great work right here in the USA.
Old Apr 16, 2011 | 01:20 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Steering Box rebuilt @ Lee Man.
I have the 680 box from Lee and it handles with great road feel.. Although more difficult when doing low speed turns but that's to be expected :P
Old Apr 16, 2011 | 02:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
what did the box work run you might i ask?
isnt 9:1 a little quick?
Old Apr 26, 2011 | 10:18 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Also interested...
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
luvofjah
Aug 29, 2015 08:33 PM
zayne0
Aug 24, 2015 07:22 PM
