1986 Trans Am Brake, Suspension, Rim Upgrade HELP
Car: 1986 Trans Am WS6
Engine: 305TPI
Axle/Gears: 3.42 (I Think)
Ok, so I've already purchased a LS1 big brake upgrade for the front, and PBR upgrade for the rear. I am sold on the 17x9 YearOne Snow Flakes...I think they look great. Now I want to lower it. I've decided on Eibach Sportline lowering springs. I understand I need a adjustable pan-hard bar, and lower control arms as well as an adjustable torque arm. If I purchased this kit:
http://www.hotchkis.net/8202_gm_fbod..._pckg_red.html
Would I still need relocation brackets? Also I have a borg warner 9 bolt. I am having difficulty finding an adjustable torque arm Any idea where I can pick one up? Any suggestions on brands other than hotchkins? I read somethings on lakewood... I am just trying to get all my parts together to do everything at once.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 1986 Trans Am Brake, Suspension, Rim Upgrade HELP
you dont really "need" any of those parts. you may need the adjustable panhard, if the axle ends up being majorly offcented, but the other parts are not "needed" just because you are lowering the car.
good shocks and struts are a must, as well as tires.
btw, that hotchkis kit is brutally overpriced
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Agreed - you will need the adjustable panhard for the Sportlines, but none of the rest.
Engine: 305TPI
Well I read the lowering 101 thread. Thats what gave me the impression of all the necessary parts. I want to do it right, and I am not against spending the money on the suspension. Any recommendations on shocks and struts?
Car: 1992 RS
Engine: Carbed 350
Lower control arms can be replaced if it makes you happy - there are certainly better options than stock. But there's no need to get relocating brackets - those are mainly used to relocate the rear for better traction at the dragstrip with slicks. Then, relocating lower control arms may necessitate an adjustable torque arm as well - again all part of getting better traction at the dragstrip, but has nothing to do with street driving.
Shocks struits would be personal preference. I love my Bilsteins, and they used to be all the rage - but they are not as popular these days as the Koni's seem to be.
Engine: 305TPI
I was under the understanding that when I lower the rear end the relocation brackets were needed to keep the rear tires centered in the wheel well. The car is not a drag car, just a really nice cruiser on nice days, otherwise she sits in the garage covered up. But I've been debating on lowering it, and don't want to mess up my alignment with a drop.
Car: 1992 RS
Engine: Carbed 350
You'll not notice any off centering, except the entire axle from left to right - that's where the adjustable panhard rod comes into play.
Engine: 305TPI
??? Thread Starter
Engine: 305TPI
Any thoughts on these UMI? Seem cheap to me?
http://www.summitracing.com/parts/UPI-201520-R/
Car: 86 Trans Am
The best street setup by far are the arms with the delrin lined joints on each side. they have the same free movement as a rod end, without the added noise.
Now for the control arm relocation brackets. the rear control arms want to be about level at ride height. the issue with the brackets is that the first new set of mounting holes are a lot lower and unless the car is lowered a crap ton, the first hole will still be a little low. So most of the time, these are more of a drag orientated part, since they can help traction.
How about an example of the control arms with "derlin lined joints". I am considering this upgrade soon and want to get it right the first time
Car: 86 Trans Am
Spohn and UMI both make a set, look them up
