Tweaked Chassis
Old Apr 27, 2011 | 07:01 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Tweaked Chassis
Well, I finished my suspension upgrade this week and got the car back on the road. The one thing that has always been a problem is that the height differences between the 4 corners of the car indicated that the chassis is slightly tweaked. Right now as it sits, I have 24 3/4" at the left front, 25 1/8" at the right front, 26 1/2" at the righ rear, and 27 1/2" at the left rear. My components are as follows, Eibach lowering rear springs with Lakewood rear control arms, relocating brackets for the rear control arms, adjustable panhard bar, with KYB shocks, and UMI adjustable torque arm with trans cross member. The front consists of lowering springs, BMR tubular control arms, Founders strut plates, KYB adjustable struts, wonder bar, and strut tower brace, the sub frames are connected as well . The car is a t-top car and though the door gaps, fender gaps are great and the doors close fine, I just can't get it sit the same height from side to side. I wanted the car to have the front lower and it looks great and handles great too. Is this something that a frame rack would have to work its magic on? Thanks for any info and help.
Old Apr 27, 2011 | 08:28 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Tweaked Chassis
Give it some time (a few weeks) - springs settle over time. When I installed my Eibach springs, my car actually raised higher for the first week or so, until the springs settled in.
Old Apr 28, 2011 | 02:22 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Re: Tweaked Chassis
Here's a pic of the car from the passenger side. The rear tire sits 1" lower on this side than on the drivers side and the front on the passenger side sits about a 1/2" higher than the drivers side. I also included a pic of the new strut plates under the hood. I will give it some time to see how it settles out, thanks.
Attached Thumbnails Tweaked Chassis-camaro-pics-002-medium   Tweaked Chassis-camaro-pics-004-medium
Old Apr 28, 2011 | 02:27 PM
Car: 1992 RS
Engine: Carbed 350
Re: Tweaked Chassis
Car looks good!
On the rear, they are easy to work with - so if still have issues in a few weeks, maybe double check the isolators or something.
The fronts are a PITA - but if you only have 1/2 inch difference, I wouldn't worry. Usually, folks don't get the fronts indexed properly, and thus end up with a major difference. But with only 1/2 inch - I'd let it ride a few weeks and see if they settle in.
Old Apr 28, 2011 | 02:33 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Re: Tweaked Chassis
Thanks for the compliment, I've had this car since 1984 and it has been an ongoing project. My wife asked me one time years ago if the car would ever be done and I told her only when they stick me in the ground or I am physically unable to enjoy the hobby. There's always something to update and change.
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
darwinprice
17
Oct 11, 2015 11:51 PM
aaron7
Sep 30, 2015 09:15 AM
SG91camaro
Sep 5, 2015 10:27 PM
