Rear strut tower brace why?
Old Apr 28, 2011 | 05:53 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I've read of folks installing rear strut tower braces but it looks like the sheet metal between the tops of the shocks should be pretty rigid. Can someone explain how much difference a brace makes and why?
Thanks.
Old Apr 28, 2011 | 06:07 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear strut tower brace why?
I'm unsure what a rear STB is. An STB fits in front of the strut mounts and eliminates flex in the unibody. Without after market strut mounts, however, which eliminates the rubber in OE mounts, the STB's effectiveness is limited.
EDIT: It occurs to me that you may be speaking about the rear of the car, not the front.
JamesC
Old Apr 28, 2011 | 06:18 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Thanks.
I don't think it'll make much difference for a thirdgen. Its just shocks there.
Old Apr 28, 2011 | 06:40 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Sort of what I thought. If the back has been weakened by cutting a hole to get to the tank I could see it if the hole wasn't welded back up but otherwise I don't see it making a significant difference.
Old Apr 28, 2011 | 06:43 PM
Yeah, there really isn't any side loading there at all. Almost ALL of the side loading force would be on the panhard bar points. Which ALREADY has a upper panhard bar brace. You could replace the upper with a stronger piece if you had flex, or suspected it. But adding a rear STB wouldn't work, we don't exactly have rear strut towers.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
