Front spring isolators
Old Apr 27, 2011 | 10:31 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
So iv tried to get the factory isolators to sit on the top of the spring 3 times now, this is as good as i could get them ( see pics below ) is this fine? i tried tape at first then zip ties. If it needs to sit on the coil and pocket better i was just thinking about pulling them out and using some hose or something else to wrap around one whole coil thoughts?
Old Apr 28, 2011 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Front spring isolators
Your attempt is probably every bit as good as the factory. I taped mine once and let'em ride. No issues.
JamesC
Old Apr 28, 2011 | 11:24 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
They get squished over time, and bent out of shape (like me!) - the only way to get better is to get new ones - but since they only serve to ensure no metal-to-metal banging noise ever occurs when your doing a Dukes of Hazard jump, it's not worth the trouble to get new to me.
Just put on your Daisy Dukes and go for it!
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
db057
Aug 22, 2015 08:17 PM
TA8487
Aug 11, 2015 09:02 PM
