What are these? Are they needed? Where can I get new?
Old May 9, 2011 | 10:33 PM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
I searched and searched, no luck. Best way I can describe these is they look like red seatbelts running vertical from the rear LCA to the frame. The one on the passenger side is ripping.
My rear springs are red, which makes me think the previous owner did an "upgrade" to the rear end.
Anyways, my rear axle is shifted a little to the drivers side, any help to straighten it out would be appreciated.
Pix of the "belts" are attached, thanks Art
Old May 9, 2011 | 11:25 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: What are these? Are they needed? Where can I get new?
i have those under mine but they are black. I wish I knew what they were, I am sure we will both find out!
Old May 9, 2011 | 11:28 PM
iroc-z_23's Avatar
Car: 1986 Iroc-z Camaro t-top
Engine: 355 SBC
Transmission: 700r4 TCI const. Pres. Valve body
Axle/Gears: 3.73 posi/mosuer axles
Probably just so when you have the load off of the rear end that your rear springs don't move around. I see it having no use otherwise
Old May 9, 2011 | 11:35 PM
Engine: MPFI
Mine are factory, so they were used for something, suspension I think..
Old May 9, 2011 | 11:58 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
My 84 has them.
I can only assume that they are there to hold the axle in a semi compressed
position to keep tension on the coil springs so they don't fall out while running
down the assembly line before the tires are mounted and the car is on the
ground.
Old May 10, 2011 | 12:06 AM
Troys88GTANotch's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 350 (CID) 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 Posi
They are called limiting straps and they keep your car suspension from extending to far...
Old May 10, 2011 | 12:26 AM
iroc-z_23's Avatar
Engine: 355 SBC
I guess if you plan on going dukes of hazard style these might come in handy
Old May 10, 2011 | 12:30 AM
I think thats what they had in mind....lol
Old May 10, 2011 | 06:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by Arvizu9618
IAnyways, my rear axle is shifted a little to the drivers side, any help to straighten it out would be appreciated.
I've never seen such a thing on an OE car (but I haven't seen them all).
Check your panhard. If bent, your issue may lie there. You could replace with an OE piece or an adjustable version from Spohn or other after market manufacturers.
An after thought: if your car is lowered, that might not only explain the red springs, the straps, but the off-center position of the rear end (though lowering usually shifts the rear to the pass side).
JamesC
Old May 10, 2011 | 07:23 AM
karl's-92'-z28's Avatar
Car: Too many cars
they keep your axel from articulating too much so you coil doesnt pop out, you usually see them on some older 4x4 trucks. Yeah you might wanna check out you panhard bar, if its lowered you may wanna get an adjustable panhard bar.
Old May 10, 2011 | 07:55 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
It would make more sense to be on the front for drag racing as limiters. But yeah, that cant be factory.
Old May 10, 2011 | 11:26 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Not just for drag racers. Limiting straps are good for anyone with really short springs. If you jack up the car and have the suspension fully uncompressed (limited by the shock travel), the springs can fall out of the pocket. These will stop that from happening.
They're used occasionally in roadracing too.
Old May 10, 2011 | 02:57 PM
You might be able to get new ones here....http://www.summitracing.com/parts/EXP-5162/ ...you just have to measure the size and see if they have them....these are 16" in length
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
