Need help with vibration
Old May 11, 2011 | 06:34 PM
rodgersje's Avatar
Hey guys this vibration is driving me nuts hopefully you can help
It happens over 60mph. Can feel it in the floor and when worse up into the steering wheel. I have had all wheels balanced. Front end is tight. Bearings are tight. Checked steering box for cracks around mounting holes, all is tight and good. Almost feels like a loose wheel. Tires are new and rims are used. I'm leaning towards a square tire. I'm out of ideas hopefully you can help.
Old May 11, 2011 | 07:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Need help with vibration
could be the driveshaft or u-joints. a bad tire, a bent wheel, a bent axle, or a variety of other things.
if the wheels were balanced by a competent shop, though should have noticed a bad tire or damaged wheel
Old May 12, 2011 | 07:51 AM
rodgersje's Avatar
tires are new but chinese which was why I was thinking it could be a tire. U-joints are fairly new about 1 year old. No vibration at any other speed could that still be driveshaft?
Old May 12, 2011 | 11:31 AM
rodgersje's Avatar
Ok I got looking around the rims. The RR wheel is pushed in at the edge of the rim about the size of a quarter. I'm guessing this could cause my vibration?
Old May 21, 2011 | 08:33 AM
EDnasty85Z28's Avatar
Car: 1985 camaro Z28
Engine: 350 pos
Transmission: trbo 350
Axle/Gears: 308
ok what im sayin gis that its a front wheel bearing ihad the same isssue check them n see if thier bad if not its gotta be a tire or rim possible a bad internal part on your power steering but if it was power steering it would do more of a jump randomly them wobble or vibrate
Old May 24, 2011 | 01:49 AM
karl's-92'-z28's Avatar
Car: Too many cars
Check your front ties, they could be seperating & may have a small lump on the tire that contacts the ground. If you have another set of rims & tires for the front put them on & see what happens? Maybe tje driveshaft, their are weights on their also, might wanna check if any came off.
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
