Front spring choice, GR2 question
Old May 19, 2011 | 08:01 AM
Guest
Guest
Posts: n/a
So, if you were swapping in a big block, but wanting to keep excellent ride quality as more important than ultimate cornering, but still wanted to not have to slow below the speed posted on the yellow warning signs, on 245/50R16 tires, what springs would you choose?
Moog's 5610s are listed as 11.00" load height, 0.69" wire diameter, 420 lb/in rate, 15.16" free height, and 2444# total front weight. The 5664s are 10.75", 0.76", 767, 13.18", and 2618.
And how about KYB GR2 struts? I'm thinking of buying and installing a pair of these at the same time, to replace my old mystery struts.
Old May 20, 2011 | 08:29 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Front spring choice, GR2 question
if you're on a budget, the GR2's seem to be the standard. They're no Koni/Bilstein, but they do beat anything in their price range (gabriel, monroe, etc).
i'll have to let someone else chime in on the springs though; I opted for a set of lowering springs for my setup
Old May 20, 2011 | 09:19 AM
Guest
Guest
Posts: n/a
Thanks, Dan!
It seems the 5610s should ride best, but not if they let it keep bouncing off the bumpstops. The 5664s being a factory item, should be tolerable? Anyone?
Old May 20, 2011 | 03:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you wopuld probably want somethint in the realm of 750-900 lb rate fromt he front springs with a iron BB. those 5610's are the ones that came stock in my v6 car.
dont skimp on shocks, seriously. if you are putting the money out for a BB swap and such, the cost of a set of koni yellows or bilsteins would be still quite resonable
Old May 24, 2011 | 12:13 PM
Guest
Guest
Posts: n/a
Thanks for that, but I missed out on that Rat, someone bid $1 more than me, in the final minute. Dammit!
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
redmaroz
Aug 16, 2015 11:40 PM
TA8487
Aug 11, 2015 09:02 PM
