Rear Springs For Drag Racing
Old May 20, 2011 | 06:16 PM
nitrous87's Avatar
Car: 87camaro 357ci
Engine: xe294,scat crank,6" rods,Dartheads
Transmission: th-350 3000 stall
Axle/Gears: 4th gen rear 4.10 gears
My third gen project is starting to come together and I decided today that it might be a good idea to invest in some rear coil spring. I have the car set up for drag racing, it has 4.10 gears with a fourth gen rear diff. I managed to squeeze 29/12/15 inch hoosiers under it by cutting the bump stops. It should be putting down about 500hp to the flywheel. What would be a good set of rear springs that would give me good launches without squatting and eating my rear tires.
Old May 20, 2011 | 10:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rear Springs For Drag Racing
The springs only need to be strong enough to hold the car up at ride height. The shocks are what do all the work. The suspension has to move so if a spring is too stiff, the shocks can't do their job. If the spring is too weak, the car squishes the springs too much and the back end sags.
I ran V6 springs for many years before installing coil overs. You can find different spring rate springs by measuring the thickness of the spring wire in the factory springs. Smaller diameter means a smaller spring rate but may also be too soft for the weight. It all depends how heavy the back of the car is.
Old May 22, 2011 | 02:20 PM
nitrous87's Avatar
Car: 87camaro 357ci
I also decided to run v6 rear springs to get more ride height. I was just worried that they might be to soft and rub the slicks on launch. The car is completely gutted so it is very light in the back. So a pair of summit or Lakewood rear drag shocks would probably be a better investment then.
Old May 22, 2011 | 05:30 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
:shrug: I'm running cut NNL springs from a 89 IROC and Koni red's set on the middle position. Rides great on the street and does well at the track.
Old May 29, 2011 | 07:21 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
shocks 90/10s front
50/50 rear. with stock springs in the rear
with stock spings in the front my 60 foot time avg 1.54
but thats with my old 383. lot better now
Old Apr 14, 2014 | 10:13 PM
cycleguy04's Avatar
Car: 1983 Z28
Engine: life is more nifty with a chevy 350
Transmission: TH400
Axle/Gears: 10 bolt, unknown gears
Originally Posted by articwhiteZ
shocks 90/10s front
Would you please elaborate what 90/10 and 50/50 mean? Thanks.
Old Apr 14, 2014 | 11:02 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
I believe its the valving in the 90/10 strut will allow the front to lift faster and come down slower, also the adjustable shocks you can just dial in to what you want
Old Apr 15, 2014 | 04:02 PM
now going with front coil overs (90/10)
and also rear coil overs & double adjustable shocks.
Old Apr 15, 2014 | 07:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I use SPA1 adjustable struts on the front. If I want to go out and play during non competition, I turn them to full loose so the front pops up quickly. During competition I crank them up tight making it hard to lift the front and I can still pull the wheels off the ground. Travel limiter cables will be shortened to keep the wheels from fully extending which makes it even harder to lift the front.
Rears have 12 way double adjustable coilovers. That way you can fine tune the extension and compression for different track conditions.
With a slower car, making the front end light and using shocks to allow quick front end extension will help transfer weight to the back. The faster you go, it becomes a problem to keep the front end down.
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
