internal coil spring compressor
Old May 22, 2011 | 11:23 AM
chris schaner's Avatar
Car: 1990 irocz camaro
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.42 posi disc 10 bolt
someone post a photo of a coil spring compressor tool and tips plese
Old May 22, 2011 | 11:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: internal coil spring compressor
Pic #5 of the following link:
https://www.thirdgen.org/forums/susp...nt-spring.html
JamesC
Old May 22, 2011 | 11:49 AM
Engine: 350 tpi
Transmission: auto
got that tool so go under car and slide it thur the arm hole and attach to the coil top and bottom coil sounds very tight ,can you remove the lower hook and make a flat piece of thick iron and place on outer a arm hole and compress that so the spring is compressed with the a arm together when installing ?
Old May 23, 2011 | 06:42 PM
bcnvz28's Avatar
Car: 16 Equinox,12 Silverado,91 Z28
Engine: 3.6l, 5.3l, 305 H.O.
Transmission: 6 Spd auto, 6 Spd Auto, 4 spd Auto
Yes you can do it that way. Also check out this link for Muscle Car TV episode. That spring compressor can be bought at
AutoZone for $33.00.
http://www.powerblocktv.com/video/?e...-07&ep_show=MC
crzycamaro86
Sep 12, 2015 05:51 PM
lakeffect2
Sep 7, 2015 03:52 PM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
Billy Decker
Sep 4, 2015 03:46 PM
