pre-made power steering line kit?
Old Jun 3, 2011 | 09:11 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Just wondering if anyone knows of a company that makes a premade braided kit for our cars,,, thanks
Old Jun 3, 2011 | 11:14 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: pre-made power steering line kit?
I don't and i never cared to look, I made my own it was easy.
Old Jun 3, 2011 | 11:27 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
I know the line has to be high pressure(2500lbs) but are the fittings any different than standard an-6 fuel line fittings? Ive done all the fuel lines on my car but Im a little aprehensive since Ive heard alot of stories of self made high pressure lines leaking
Old Jun 3, 2011 | 03:47 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
any fitting on the pressure side, or any side to be safe, should be steel, hose should be high pressure teflon.
there are no "kits" because the return line loops across teh front of the radiator working as a "cooler"
the box fittings are 16 and 18mm 1.5 o-ring fittings, and they iuse -6AN fittings. I like the premade teflon hose setups that summit and jegs sell made by "fragola" (spl?). high quality stuff and you dont have to assemble the fittings, which in the teflon tubing is a nightmare, i could never get mine to seal. You need to then pick up a universal cooler and mount it in front of the radiator, measure for line lengths and order. I dont know what fittings are needed to attach tot he stock pump, since i dont have a stock pump.
Old Jun 4, 2011 | 12:12 PM
FueledSoul's Avatar
High side: I used Stainless AN fittings and Teflon lined braided hose.
Low side: New factory PS cooling line, Your average 6AN Braided house and fuel clamps. I installed everything my self and iv had zero problems and no leaks.
Old Jun 4, 2011 | 02:38 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
that looks great too FueledSoul
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
fasteddi
Sep 2, 2015 10:29 AM
mdtoren
Aug 23, 2015 12:52 PM
