size of nut on pitman arm
Old Jun 3, 2011 | 06:38 PM
thumperz's Avatar
the nut that connects the pitman arm to the steering box,what size is that? 1 1/2? the biggest i can find in my tools is a 1 /14. i dont wanna go out and buy multiple sockets.
been looking,but i cant seem to find a book on the camaro.
Old Jun 3, 2011 | 06:48 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: size of nut on pitman arm
Put a small ruler up against it to measure from a flat to opposite flat.
I love Harbor Freight (if you have one close by) for these things - can get great cheap tools there for these odd minimal use jobs - and save the cash for really nice daily use tools from better makers.
Old Jun 3, 2011 | 07:39 PM
3WindCoupe's Avatar
I just took one off an '88 GTA; 1 5/16" and Harbor Freight doesn't have one. AutoZone had one for about $7-8 (less than half the price of Sears) and Tractor Supply has an even cheaper one. Bad news - it's 3/4" drive so off to HF to get a 3/4" breaker bar ($17 - 20% discount coupon). I also used a 2' cheater pipe and it came off smooth as butter (160 ft-lbs).
Old Jun 3, 2011 | 08:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i have to check tommorow, but its actually 33mm IIRC (maybe 32?), its defiantly metric. its a bit odd, but most auto parts stores have the large sockets. got on at autozone recently.
*edit*
checked one of my old threads, its 33mm
Old Jun 3, 2011 | 09:38 PM
3WindCoupe's Avatar
http://www.camaros.net/forums/archiv...p/t-98560.html
I just measured mine by vernier caliper and it is indeed 33 mm. 1 5/16"
will work but it's loose.
This also may be of interest after the nut is off and the second adventure begins:
http://forum.ih8mud.com/40-55-series...oval-help.html
Old Jun 4, 2011 | 05:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
yeah, you need the puller too. again, most auto stores have the cheap ones, they will work. not sure how may times after the first time they will work before they break, but once is usually enough.
Old Jun 4, 2011 | 11:08 PM
thumperz's Avatar
yup,the 1 5/16 worked.
New2Chevy
Sep 28, 2015 12:35 AM
Linson
Sep 21, 2015 01:08 PM
timonator
Sep 10, 2015 07:55 PM
BOOT77
Sep 5, 2015 03:55 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
