Do BMRs fit on a stock K member?
Old Jun 4, 2011 | 08:11 PM
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
As the topic says, do BMR A arms fit on a stock K member? I'm tossed up between BMR and UMI. The BMRs have the spring indexes and bump stops like factory, last I heard UMI was still working to put spring indexes on theirs. I'm not worried about the bump stop, but I want the spring index.
I'm keeping my factory K member, doesn't make sense to go tubular with what I'm building here.
Old Jun 12, 2011 | 08:48 PM
jrz28's Avatar
Car: 1984 Berlinetta
Engine: 305 Carb
Re: Do BMRs fit on a stock K member?
I talked to Lee at BMR via email a few weeks ago and he told me that BMR A arms will work with the stock K member.
Old Jun 13, 2011 | 04:12 PM
87350IROC's Avatar
Car: 87' IROC
Honestly I would forget the tubular a-arms and just rebuild your factory parts in that case. There are lots of reports of people having problems with tubular a-arms from all the manufacturers. And this is coming from a Spohn a-arm owner whose arms fit fine. You are just asking for trouble for minimal gain and great cost.
Old Jun 13, 2011 | 05:28 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
no weight savings from the stamped factory ones, so I just did the tubular kmember and am running stock a-arms instead.
Old Jun 25, 2011 | 10:25 AM
L695speed's Avatar
Sorry guys, I've been busy haven't had time to play around on the boards. My stock A arm on the driver's side bent while having new bushings put in. Cost of getting another arm, bushings, paint, ball joints, etc. Seems to be better off just getting a new set of arms all together. I can't recall if any of the resto companies are reproducing factory arms, let alone with polys. I'm not after weight savings too much. What I meant by "it doesn't make sense to go tubular" in my original post was the K member.
Jeremys87
Jul 14, 2022 09:08 PM
customblackbird
Aug 15, 2021 10:16 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Linson
Aug 21, 2015 02:12 PM
sreZ28
Aug 14, 2015 07:48 PM
