pitman arm removal ideas?
i got the 1 5/16 socket tyoday,got the nut off,got a pitman are puller,but 24 years of rust kicked my *** today! im gonna let it soak in pb blaster overnight,any ideas on getting through. i cant take it to school to use a lift,i was thinking of just taking the idler arm and center link off at the ball joints. watcha think?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: pitman arm removal ideas?
A puller is about the only way to remove it without damage. I've always used an old GM puller that wraps around the pitman arm. I've never had any success with the pullers that have the 2 arms on them.
One of these and an impact gun and the pitman arm should easily come off.
Car: 1991 Camaro RS
Engine: 305 TBI
Maybe heat it up with a torch? PB Blaster always seems to do the job, but when they are really stuck, a little heat usually works.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
get a cheap puller form the auto parts store. you dont need air tools to use them, but they help.
Car: 92 z28
Engine: fast burn 385
Transmission: t56
mine was a paint in the butt when i had to do it. i actually had someone help me with it. put the puller on it and tighten it as much as you can, then get a hammer and hit it a few times. you wont hurt this part, and you can even use a small sledge hammer. thats how mine came off about 2 or 3 years ago and no problems at all since - that piece is really thick and will take a beating
i got it off today. let some pb blaster soak for an hour,bingo. i have to adjust the steering,its off alil bit. theres a dead spot with the steering wheel. gonna adjust that plug and put it back in later on.
1992rs/ss
Jan 31, 2025 05:10 PM
Fronzizzle
Mar 18, 2019 08:29 PM
ambainb
Apr 25, 2016 09:21 PM
