need advice for my MOOG bushing and links
Old Jun 9, 2011 | 10:01 PM
joekaz1070's Avatar
Car: 1987 Trans am
Axle/Gears: GM 10 bolt
Have a 87 TA with a 36mm front and 24mm rear sway bar. I purchased the blue thermo plastic links and bushings from MOOG.
1- Can I or should I put Super Lube on the bushings and links before install.?
2- Should I hand tighten assembly bolts or do they need a specific torque?
3- Can I use the synthetic Super Lube to grease my joints? I'm wondering if will be a problem when it comes in contact with the regular grease from prior lube jobs?
J-money
Jan 4, 2019 09:45 AM
64goatman
Sep 9, 2015 01:09 PM
383cam
Sep 9, 2015 06:01 AM
mrdevontay
Sep 2, 2015 08:04 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
