Easier with motor out?
Old Jun 13, 2011 | 12:36 PM
startat2's Avatar
I'm currently rebuilding my motor and have it out of my camaro. Is it any easier to rebuild the front end (bushing shocks and springs) with the motor out, or about the same either way? My motor should be back from the machine shop wednesday, and I really want to get it knocked out, but if its easier to do my front end with it out I will be patient. What does the general population say?
Old Jun 13, 2011 | 12:45 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Easier with motor out?
You can replace everything but some of the bolts should not be fully tightened until the engine is back in and the car is sitting on it's wheels. Check your manual which ones.
Old Jun 13, 2011 | 04:20 PM
The motor isn't really in the way of any front end type parts all that much.
However, I'd STRONGLY recommend changing out your motor mounts; and they're AHELLUVALOT less if a hassle to get off while the control arms are off. So I'd say, go ahead and do the front end while the motor is out.
Make sure you get a GOOD spring comrpessor though, because you probably won't have enough weight to compress new springs enough to put the strut back on the spindle. You'll need for the compressor to be stout enough to do that work for you, but still be able to get it back out after it's all assembled.
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
86White_T/A305
Aug 17, 2015 12:16 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
