Driveshaft loop on stock TA
Old Jun 24, 2011 | 10:43 PM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
Axle/Gears: Too lazy to check!!
Do you think I will be ok welding a saftey loop to my stock TA? Has anybody ever done that before? If so do you have any pictures?
Old Jun 24, 2011 | 11:17 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Driveshaft loop on stock TA
If it's stock, your not making enough power to need one - why bother on a 235hp car?
Old Jun 25, 2011 | 03:11 AM
EvilCartman's Avatar
Car: '82 Z28
Just get the proper one that bolts to the floor.
camaronewbie, here's a couple reasons why he may need to run a loop. These might not be up to date but it's what I found really quick, from '07.
13.99 Drive shaft loop (slicks)
11.49 Drive shaft loop (street tires)
Old Jun 25, 2011 | 03:18 AM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
It isn't stock it has a turbo charged LQ4 and my track requires it.
Old Jun 25, 2011 | 03:22 AM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
1. I have a Longtail TH400 and nobody makes a crossmemeber with it built in.
2. I have the lakewood one but with my exhaust and tranny combo it doesn't fit correctly.
Sooooooo the question still remains. Will I be okay going to the TA like the aftermarket ones?
Old Jun 25, 2011 | 08:54 AM
ihatemustangs's Avatar
Car: 74 z28, 89 IROC, 98 Z28, 91Z Vert
Engine: 383, 350, 347, 305
Transmission: th400, 700R, T-56, 700R
Axle/Gears: 3.42, 3.45, 4.10, 3.08
Not sure how NHRA rules are. Most aftermarkets are on the crossmember or bolted to floor. Try checking out ebay. I saw some of the ones for 3rd or 2nd gens that bolt of your trans mount. Maybe it could be extended to be made work and cheap. http://cgi.ebay.com/ebaymotors/67-81...item25582e9d53. I asked a friend and thats the one he made work in his second gen with a long tail 400. Good Luck
Old Jun 25, 2011 | 09:19 AM
Car: 1992 RS
Engine: Carbed 350
OIC - you stated ...
Originally Posted by rockoosi1
... a saftey loop to my stock TA?
so I was confused.
Old Jun 25, 2011 | 09:33 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
im making a bunch more power than stock and i have never really considered a safety loop... i always thought that was more of a drag racing type safety equipment..... and the ones that ive heard say they are poor fitment issues and causes vibrations and may interefere with the driveshaft itself.... besides how often do you hear peoples u-joints are sooo bad that it causes the driveshaft to disconnect and fall out.... thats what its really for...
Old Jun 25, 2011 | 11:55 AM
Its not a matter of u-joints being bad, its the part failing, or something else like the rear or trans breaking causing it to come off. I had a stock rear blow once and blow the driveshaft off on a 12 second street car, not pretty, nice big tear in the floor. He runs at a track and its required.
Old Jun 25, 2011 | 07:36 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
It is not a bad idea to run just for safety issues. You can make your own with thick enough metal and a torch to heat it up to bend. that way you can make it clear. Then bolt it inside to your floorboard and you'll be set.
Genopsyde
Oct 7, 2015 08:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
CORV3TT3
Aug 23, 2015 11:26 AM
Dialed_In
Aug 20, 2015 01:45 PM
