Ball Joint Removal
Old Jun 26, 2011 | 02:47 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Ball Joint Removal
Which way do i press them out? i tried flipping the a-arm over (grease zerk was pointing upwards) and pressing it out and no luck.
Do i press it out with the zerk on the bottom?
Old Jun 26, 2011 | 02:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Ball Joint Removal
they are pressed out from the top. so the zerk would be on the bottom when removing, so you would have the arms int he press the same orientation they would be if they were still installed in teh car and press down on the joint around the stud
they are usually really tight, especially if they have never been removed before. Hope you have a good press
Old Jun 26, 2011 | 03:33 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
F me sideways i was pressing the wrong way! I'm going to try it now,
Old Jun 26, 2011 | 04:33 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Came right out thanks a lot!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
