sway bar question
Car: 1987 Sport Coupe
Engine: Carbeurated 5.7
Transmission: NWC T-5
Axle/Gears: Non-posi 2.73
sway bar question
How do I connect a front sway bar to a camaro that didn't come with a sway bar on it. I'm looking at buying an iroc sway bar from a friend but don't know if it will fit my 87 sport coupe
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: sway bar question
AFAIK, evey 3rd gen came with afront bar. not all had rear bars, bet definatly a front one. your was removd at some point, probably for drag racing purposes.
if you get under the car, you shoudl be able to the the mounts on the frames just behind the radiator on each side.
you then just need bolts, dont know the size offhand, but probably 10mm 1.5 grade 10.9, and the bushing saddle mounts, bushings, endlinks and the bar.
Car: 86 Trans Am
ProtoMaster22
Aug 26, 2015 07:50 AM
