Manual Steering box question.
Old Jul 20, 2011 | 12:52 PM
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
I ordered this about three days ago. http://www.jegs.com/i/Procomp+Motors...C2251/10002/-1
I need a manual steering box but can't seem to find out which one will work in my Camaro.
It's a '85 Z28,I'm building a serious street/strip car so I don't need the power steering and I am getting antique plates so it's not going to be a daily driver.Can anyone help?
Old Jul 20, 2011 | 01:26 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Manual Steering box question.
AlkyIROC has all the info you would need.
Certain yrs S-10 manual box with 4 bolts on the cover, NOT 3 bolts.
Use you pitman arm.
I can't recall the thread title, but a quick search will give you quite a few threads covering every detail. IIRC, a few ppl used the S-10 pitman arm.
See if this helps-- In you search box go to Advanced search
put in-- manual steering
manual steering swap
or manual steering box
In the User Name-- put in AlkyIROC
This **should** give you everything AlkyIROC has done to his & how he went about it. My search skills are near nonexistant!!LOL
Or in your search box just put in the same words listed above but don't enter a username. Again, there **should** be quite a few threads with tons of info!!
Good luck
Old Jul 21, 2011 | 12:21 AM
Seven_MPG's Avatar
Car: 1985 Z28
Awesome,Thanks for the help
1992 Trans Am
May 10, 2023 07:19 PM
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
zayne0
Aug 24, 2015 07:22 PM
