SFC comparison thread
Old 09-05-2013, 11:08 AM
  #201
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: SFC comparison thread
I run both. Mac and SPOHN. I like both. Inners are beefier and tie the front subframe directly in a straight line to the rear subframe. The outer style has a tube run along the rocker that is stitch welded along the rocker (I've jacked the car from these and they work really well) and then there's a tube that connects the front part of the outer tube to the front subframe, and the rear end of the rocker tube has a small tube that tie into the rear LCA mount part of the frame (not the beefy rear subframe). So, the inners and outers tie in different parts of the subframe/body/rocker..
Also, yeh I've been looking for those KB pieces for a couple years now.. No luck
Old 09-06-2013, 03:53 AM
  #202
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Thanks for your input. Yeah I think I have a pretty good idea now of the inner and outer design, just not sure which one is better or for what application.. Anyways prolly gonna get both as said
Which ones are those KB pieces?
Does anyone know if you can stitch weld the UMI boxed ones to the rocker rails or are they too far away to do that? Summit has a 2 weeks backorder on the GlobalWest :/ I kinda have to get the SFCs from Summit because of shipping options..
Old 09-06-2013, 09:26 AM
  #203
The KB bolts into the front subframe near the front of it (sort of like under where the tranny and engine meet) and ties in both sides of the frame under there.
Old 09-29-2013, 10:44 AM
  #204
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
I just welded in the Spohn connectors for my 91 convertible. Not many options for a vert. I screwed up and ordered the powdered coated ones. I didn't realize that I would have to sand it off to weld it in. I'll let you all know if they do whet they are advertised to.
Old 11-03-2013, 05:00 PM
  #205
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I bought my "alstons" back when Saleen sold them w/ Areo Camaro labeling.Been on the car 20yrs now.Bolted on first, then welded.
Nice thing about these they fit coupes/verts & single/dual cat exh.
Old 12-06-2013, 01:19 AM
  #206
AssaulT/A's Avatar
Car: 1986 Trans Am
Axle/Gears: 3.08? unlimited slip
FueledSoul, is there any chance you would be willing to make and sell me a set of those connectors?
Old 06-22-2014, 07:36 PM
  #207
TxTtopZ's Avatar
Car: 1989 G92 IROC-Z
Engine: 5 Liter 305
Axle/Gears: 3.45
After reading this entire thread and searching every thread I could find on every subframe connector still offered I have but one solid piece of info. Nobody agrees as to which is best. S&W looks like a better kit than most, but the cross bar hangs really low. Looks like going with the perimeter style along with the alstons is the best bet.
Is there anyone running a Mufflex 4" system with ANY of these connectors?
Old 06-22-2014, 08:26 PM
  #208
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Its very easy.
Alstons take a very pricy hydro from machine to build and shape the tube.
All the rest you can make at home with square stock and a welder.
Old 11-27-2014, 08:13 PM
  #209
85Z28NOS's Avatar
Car: 85 Camaro & 84 Fiero
Engine: 350 HSR
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
I run the UMI perimeter ones with my 4" Mufflex. Also had purchased and trial fit the TDS ones to add but used them on my firebird instead. Now I just purchased a set of MAC's inner ones to install. They all clear just fine
Old 02-22-2015, 04:19 PM
  #210
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
I have a set from UMI
Old 02-22-2015, 04:27 PM
  #211
ownor's Avatar
Engine: LS1 / L03
you dont say..
Old 03-25-2015, 04:52 PM
  #212
85Z28NOS's Avatar
Engine: 350 HSR
I tried to mount the MAC inner ones on my camaro today. Camaro already has UMI perimeter ones on it and found they wont install if you run a spohn t56 crossmember. already ordered a Hawks crossmember for the Firebird so will check when it arrives. Might have to buy a second one
Old 05-26-2015, 12:24 PM
  #213
KITT1983's Avatar
Any difference with the subframe connectors versus without?
Old 05-26-2015, 01:36 PM
  #214
85Z28NOS's Avatar
Engine: 350 HSR
I noticed more when I put the perimeter ones on my camaro than I did when I put the inner ones on my firebird. But the camaro had bad door hinged and was overall in a loose and rattle prone compared to my firebird which was tight and doors closed perfect. In short, yes they make I big difference. But you can only run perimeter if you have any aftermarket crossmember due to a trans swap. Inner won't clear hawks or spohn T56 or 4L60E. I tried them both on both cars
Old 05-26-2015, 02:31 PM
  #215
I have MAC inners and SPOHN outers but was hoping one day to do an LS1 swap.. That kinda sucks, I guess I would have to cut the inners out or something.. Wouldn't a 4L60E fit in the 700R4 stock crossmember? Doesn't the 4L60E have the same external dimensions as the 700R4?
Old 05-26-2015, 03:08 PM
  #216
85Z28NOS's Avatar
Engine: 350 HSR
The LS 4L60E is set back just like my LT1 T56 in my camaro. Only thing I notice is the bellhousing is different on the ls. I have to cut out mine on the firebird to use the hawk crossmember. Actually going to try to modify it to still work. Just bought a set of BMR perimeter for the Bird cause my goal was to run both on both cars.
Old 05-26-2015, 08:40 PM
  #217
85Z28NOS's Avatar
Engine: 350 HSR
I went back and double checked my facts. Yes the ls 4l60e had a different mount location than the 700r4 & lt1 4l60e but the over all length is the same
Old 06-19-2015, 09:29 PM
  #218
85Z28NOS's Avatar
Engine: 350 HSR
BMR perimeter w/TDS aka Alston inner will work with minimal modifications using a hawks crossmember. UMI perimeter will also work it's the Mac inner ones that seen se be the problem.
Old 06-28-2015, 05:54 PM
  #219
ur7x's Avatar
Car: 83 Z28, 87 442 (Sold)
Engine: 5.0, 5.7,
Transmission: 4 Speed autos
Originally Posted by brodysZ28
Originally Posted by SCCAjunkie
Anyone know why these are listed as 86-92? I have an 84 Z28, so I'm wondering if there's a fitment issue...
http://www.macperformance.com/store/...Product_ID=434
Seems like that is a great deal, and I need inners due to my exhaust system.
http://www.ws6project.com/user_stor/...owder-coated-/
However, I have an 83. Will these really not work on pre-86 cars? I didn't see this question answered yet... maybe I missed it.
I too have a 83 Z28. (LG4) a local club member basically gave me a pair of the Mac's (for a beer).
Do they fit the 82-85 cars?
Sorta
The Driver side is a perfect fit (just protect the gas and brake lines prior to welding). The issue on the passenger side is not the transmission mount/crossmenber, or what have you. The issue on the older cars is the "massive" pellet style catalytic converter used in many of these cars. If you plan to keep the stock exhaust and the stock catalytic converter then there is not enough clearance. but if you swap in new OE cats or smaller aftermarket cats then it will fit your 83 just as nice as an 86-92.
Old 09-18-2015, 09:59 PM
  #220
Armored91Camaro's Avatar
Car: 1992 Camaro RS Heritage Edition
Engine: LO3 305 5.0L v8
Axle/Gears: 10 Bolt Factory 2.73 Open
I figured i would upload my home-made sub-frame connectors, iv had them on the car for about a year now..passenger side is not complete yet though..All the driver side needs is to have a plate that boxes in the rear LCA mounting location...i used Square tubing and an arc welder.. 1"x1"x5/16" square tubing.
Attached Thumbnails SFC comparison thread-20150918_131822.jpg   SFC comparison thread-20150918_131838.jpg   SFC comparison thread-20150918_131854.jpg   SFC comparison thread-20150918_131900.jpg
Old 09-19-2015, 01:08 PM
  #221
Twin_Turbo's Avatar
Not to be an as.s, but I would take it to a shop or anyone with a mig welder and lay a hot bead over the welds already there, maybe grind them down a little. Kudos for DIY Just trying to provide some advise, not meant as an a hole comment
Old 09-19-2015, 05:05 PM
  #222
The welds look worse than they are, i used 6013 3/32 rod for pentration which does go all the way through because where each tube meets i did a V notch and did multiple weld then grinded down then did a one pass over with the 7013 1/8" and only grinded down where it meets the floor pan no need in making the welds look 100% perfect on top of the metal,for as noone knows i have them until i tell them..although i will be taking it to a muffler shop to have them welded into place on the pinch area and on the from subframe.
Old 10-24-2015, 08:44 PM
  #223
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Originally Posted by 3rdgenmaro
because you have to cut the floorpan to install them
see , that sinks their ship . as far as im concerned. im looking for SFCs that just plain fit. but i guess its same as with headers. "some hacking required" and , really ? F that !!
Old 01-06-2016, 01:15 PM
  #224
BrutalGTA's Avatar
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
Does anyone have the S&W subframes installed?
I would love to see a picture on car before I order them.
Along with the torque arm, this might be a great setup for my LS3/80E swap!
Old 01-07-2016, 09:06 PM
  #225
KustomKreationz's Avatar
Just a heads up, JEGS has the umi subframe connectors on sale for $177.09 with free shipping....
http://www.jegs.com/i/UMI+Performanc...400-R/10002/-1
Old 01-07-2016, 10:06 PM
  #226
BrutalGTA's Avatar
Car: 1989 GTA
Wow! Those look really nice for $177!
I might have to buy these..
Old 01-08-2016, 12:19 AM
  #227
Twin_Turbo's Avatar
The only thing I hate about those is that stupid seperate tab, it means grinding the powdercoat and welding, making for an ugly finish. It's done to clear the stock exhaust. They might as well have built it to be bolt in.
Old 01-08-2016, 01:33 PM
  #228
BrutalGTA's Avatar
Car: 1989 GTA
What tab are you referring to??
Old 01-08-2016, 02:33 PM
  #229
Twin_Turbo's Avatar
The little bar with tabs for the passenger side front. Its in the pic
Old 01-08-2016, 04:27 PM
  #230
BrutalGTA's Avatar
Car: 1989 GTA
Is this the piece your referring to?
http://umiperformance.com/catalog/im...2400af_LRG.jpg
Old 01-09-2016, 05:17 AM
  #231
Twin_Turbo's Avatar
Yes
Old 01-11-2016, 11:07 PM
  #232
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Adding my 2¢.Global West along side my pre-Alston SFC.I went with GW because they tuck away really nice, but mostly cause they are tubular...as well.
Old 01-12-2016, 03:58 AM
  #233
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Dang, and I thought I got a deal at $206 shipped.
Old 01-12-2016, 07:49 AM
  #234
BrutalGTA's Avatar
Car: 1989 GTA
Did you have these stitch welded or just on the mounting points?
Old 01-12-2016, 07:52 AM
  #235
BrutalGTA's Avatar
Car: 1989 GTA
It's only $29 difference. I'll confirm they are 177.09 shipped. Ordered mine yesterday.
Old 01-12-2016, 11:59 AM
  #236
Ty92Z's Avatar
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
Bought a set of UMIs and was wondering if I should coat everything with weld thru primer since I have to get to bare metal on both the car and sfcs? Don't want any rust to invade later on.
Old 01-12-2016, 01:12 PM
  #237
Twin_Turbo's Avatar
That's what I do and priner top coat and urethane sealer like for body panels and windshiwlds afterwards. Finger dipped in soap let's you smear it out to a clean bead
Old 01-12-2016, 05:29 PM
  #238
Ty92Z's Avatar
Engine: LB9 LO3
Thanks. Have never used weld thru primer before, is one any better than the other? How does it affect the welding process, any different than welding bare metal?
Old 01-14-2016, 09:05 PM
  #239
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Hard to tell from the pics, but i did both.As per GW instructions, which are crappy btw.
Old 01-14-2016, 09:18 PM
  #240
BrutalGTA's Avatar
Car: 1989 GTA
They seem to tuck well, any interference with the floorboards?
Old 01-14-2016, 10:15 PM
  #241
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
None at all.Almost like that space was made for them.
Old 01-31-2016, 06:32 AM
  #242
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
I bought the Alstons, but didnt get them installed yet. I like that they tie in the subframes directly. How about jacking? From what Ive seen they would provide good jack points for the rear, but how about the front? Or can I jack up both wheels if I put the jack in the middle between the wheels?
Old 01-04-2017, 09:39 PM
  #243
Jeremy85's Avatar
Car: '85 Camaro
Engine: LG4
Transmission: 4L80E
Axle/Gears: 3.42:1
Yeah, I don't even have a third gen yet, but I've been presearching. So the inners are either Mac or Alston? I can find the Alstons from TDS and Hawks,can't find the Macs period.
I really like the theoretical strength advantage of outers that require cutting through parts of the floors, but what about carpet fit?
I'm also liking the outers that connect to multiple points at either end, but these seem to call for a more traditional exhaust routing, right?
Old 01-04-2017, 10:00 PM
  #244
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Looks like we are in the vast minority in that there aren't too many people on here running the GW SFCs. I love mine. Tucked up under there nice and tight. Fit perfect and they blend in nicely with the undercarriage.
Old 01-09-2017, 01:35 AM
  #245
Twin_Turbo's Avatar
are those close enough to be welded to the rocker pinch?
I designed and fabbed my own and added welding tabs so I could do just that. a little dirty from sanding dust etc from paintjob
luvofjah
09-26-2015 08:28 PM
Linson
09-21-2015 01:08 PM
dbrochard
09-19-2015 08:13 PM
luvofjah
09-10-2015 10:41 AM
85Special
09-03-2015 04:21 PM
Quick Reply: SFC comparison thread
