can these chassis be to stiff?
Old Aug 16, 2011 | 12:32 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
was just wondering what everyone thought?
i would think that it would just induce a lot of over steer right?
Old Aug 16, 2011 | 11:10 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: can these chassis be to stiff?
Not if the suspension is setup properly and doing it's job properly..
Old Aug 16, 2011 | 11:58 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I guess it could be. If you didnt have shocks or springs and just welded everything together so it didnt move, yeah it would be "too stiff"
Old Aug 20, 2011 | 12:55 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Ever drive a demolition derby car on the street with welded shocks? Its not fun.
Old Aug 20, 2011 | 01:27 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
On a solid rear axle car, too much rear roll stiffness can lead to excess oversteer.
As for the chassis itself, it can't be too stiff.
Springs & shocks can be.
Old Aug 21, 2011 | 06:25 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
hmm..i see..i mean like..for a street/autox setup? as a whole, can a car be TOO rigid to the point where it tracks like **** and just oversteers and slides?
Old Aug 21, 2011 | 07:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
what do you man by stiff? if the suspension is too stiff, the car will suck, it will slide and ride really poorly. If the chassis, structurally is really stiff, thats rarely a bad thing. Less deflection in the chassis mean more precise and predictable suspension performance
Old Aug 21, 2011 | 07:52 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
i meant the chassis/structural rigidity of the car..ie subframe connectors, wonderbars, strut tower braces, roll bars etc..is there a point in which its just over kill?
Old Aug 21, 2011 | 08:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
it will only "hurt" the weight of the car. But if you keep those parts light and well designed, and reduce weight elsewhere as you can, there will be few disadvantages. Keep in mind, with a full roll cage, you dont need 3 sets of subframe connectors, and you may not need a STB if you incorporate the cage to the strut towers.
Old Aug 21, 2011 | 08:14 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
hmm..well for my specific setup
i have bmr sfc's, umi wonder bar and a bmr strut tower brace as well as all the supporting suspension mods..just trying to determine whether an 8point roll bar would be a good/bad thing for my setup? cuz i want the increased rigidity as well the aesthetic improvement of a roll bar..
Old Aug 22, 2011 | 02:22 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Your over thinking things...........
Old Aug 22, 2011 | 04:34 AM
DIGGLER's Avatar
your car is still floppy without a full cage.
Old Aug 23, 2011 | 05:49 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Aesthetic improvement should never be the reason for installing roll protection. It takes a lot of research to properly install a roll bar or cage in a car that is street driven while keeping it safe. Bump your head on a bar in a parking lot collision and you'll be getting coloring books for the rest of your life. If you aren't going to install the cage yourself you need to have a qualified professional that understands safety and street use with roll bars do the work for you.
For our applications, the chassis can't ever be too stiff, but I doubt you really need a roll bar. It's adding weight you don't need unless you're racing and need the protection, or unless you've got a fixed racing seat and harnesses installed.
Old Aug 23, 2011 | 06:23 PM
87350IROC's Avatar
Car: 87' IROC
Aesthetic improvement? As has already been mentioned, roll bars are not for looks. Quite frankly they are a huge pain, and should only be considered if needed.
Old Aug 23, 2011 | 08:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
could always build the legendary PVC roll bar.... if we are looking for aesthetics
Old Aug 23, 2011 | 09:30 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
matter of opinion..i dont mind the bar in the way..thanks tho
yea ive seen that a couple times..lol..not my cup o tea
darwinprice
17
Oct 11, 2015 11:51 PM
aaron7
Sep 30, 2015 09:15 AM
gord327
Sep 29, 2015 10:18 PM
Chad Speier
Sep 24, 2015 12:32 PM
SG91camaro
Sep 5, 2015 10:27 PM
