strut rod/A-Arm conversion
Old Aug 21, 2011 | 08:53 PM
kfowler4444's Avatar
sorry if this has been covered before I used the search and didn't find anything
is there a somewhat easy way to convert our suspensions over to A-Arms
this is the first car i've had with strut rods and am trying to make a road race car out of the old girl but don't know how to set my ride heights and cross weights and such with a strut rod car can it be done or can i convert this style suspension to A-arms
Thanks in advance
Old Aug 21, 2011 | 10:55 PM
87350IROC's Avatar
Car: 87' IROC
Re: strut rod/A-Arm conversion
These cars do have a-arms. They are a McPherson strut suspension. I think you are asking if there is a way to convert to a coil over strut suspension?
There are a few manufacturers that make coil over kits, but in my opinion they are nut suitable for a road race style car as the strut towers in these cars are not designed to hold the weight of the car.
A good way to adjust ride height and corner weights in these cars is to use weight jacks like the ones from ground control. They allow easily height adjustments while keeping the springs in the stock location.
http://www.ground-control-store.com/...hp/II=20/CA=86
Old Aug 21, 2011 | 11:24 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
You can switch to a coil over suspension but it sure is expensive. I bought sphon's coilover kit, wonderbar, and a BMR 3 point strut tower brace.
Old Aug 22, 2011 | 04:36 AM
DIGGLER's Avatar
the car would have to be pretty radical overall to justify changing to another style front suspension. the struts still work quite well.
Old Aug 22, 2011 | 09:25 AM
i was referring to the top "strut"? vs. having a upper control arm(A-Arm) i think those weight jacks are the way ill go thanks
that make it look familiar ive raced stock cars for years at various levels which all have the a arms so this is m first venture with struts
Old Aug 22, 2011 | 09:43 AM
DIGGLER's Avatar
might be easier/cheaper to run a 4th gen instead? they have an upper control arm.
Old Aug 22, 2011 | 10:14 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
ive thought about doing it and it all depends on your fab skills the C10 guys are always making thier own front suspensions with upper lower A Arms but I dont think the benifit would be there unless you were trying to loose weight and get rid of the inner fenders and then you are opening a whole new can of worms
Old Aug 22, 2011 | 10:45 AM
87350IROC's Avatar
Car: 87' IROC
Yeah, I'd try the stock style suspension first. These cars handle VERY with a properly setup stock style suspension. Also, I would be surprised if a double a-arm design was lighter.
Old Aug 25, 2011 | 10:05 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
you really have to know what you're doing to even attempt to convert to a long arm/short arm suspension from a strut setup. weight jacks are your answer, as mentioned above.
Linson
Oct 24, 2025 02:00 PM
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
