Shock/Strut Adjustment
Old Aug 25, 2011 | 01:36 PM
BonesNIS's Avatar
Car: 1987 Camaro Iroc Z
Good day
I just install Eibach Pro-Kit Lower Springs (1") and was wondering what setting would be best to set my new Koni shocks/struts. I also installed UMI Performance Pan Bar, RLCA's and LCA's. Thanks, your assistance is appreciated.
Old Aug 26, 2011 | 06:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Shock/Strut Adjustment
I'd suggest experimenting a bit. I did and wound up on full soft.
JamesC
Old Aug 26, 2011 | 09:50 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
A good starting point is middle on the front & full soft on the rear.
Then experiment... Adjust the front first.
Obviously soft will ride the best, but for handling as you stiffen the shocks turn-in usually improves & the car gets more responsive. Adjustment depends on what you want to do with the car.
For handling, find a long turn where you can repeatedly test the car.
Work slowly & carefully so you do not kill yourself. An offramp is typically a long sweeping turn that you can repeatedly test on.
You essentially have to push the limit until the car starts to slide entering the turn. Try that same speed again with the front shocks slightly stiffer & see if it improves.
If so, increase speed & repeat the above test. Keep going until the car starts to slide then catch on initial turn-in, at this point you are too stiff & back off the setting to verify.
If the car immediately gets worse on the first adjustment, loosen the shocks & repeat working in the softer direction.
The only correct setting is what your car likes... there is no specific setting.
I was lucky on mine, tigtened front 1/4 turn from middle & it improved, added another 1/4 & is started sliding on corner entry.
Went to the rear & tried 1 step stiffer & it got loose.
I was basically done.
Old Aug 26, 2011 | 11:28 PM
BonesNIS's Avatar
Thanks for the tips, I'll post how it all turned out.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
