Transmission Mount
Old Aug 22, 2011 | 10:26 PM
driftmaster81's Avatar
Car: 1983 Camaro Z28
Engine: Chevy Nova 5.7L 350 Carb.
Transmission: Manual
Axle/Gears: Stock
Transmission Mount
Today I was on the road and suddenly my shifter dropped down like 5". I got home and looked underneath the car to find the whole transmission lowered. The bar that goes across the transmssion under it, that the tranny mount is attached to has rusted through on one side and broke! So only one side of this bar is attached.
I am not driving it until I get it to a body shop or mechanic but I would like to know how bad it is.. I don't know if its actually part of the frame or if it is a seperate piece you can bolt on and replace??
I just hope the fix doesn't cost more than the car!
Old Aug 23, 2011 | 05:54 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: Transmission Mount
Tranny crossmember. Easy, cheap (should be) fix. One from a third gen A4 or 5speed will work. 4 bolts, 8 if you count the 3 on the tranny mount- replace that while you're in there. Most boneyards should have them. Good luck!
Old Aug 23, 2011 | 06:10 AM
Depends to some extent on what actually rusted through and broke, but then again, maybe not...
If it's just the crossmember, you can get a junk one and change it out. But that is,,, .... unlikely ..... to do any good, to say the least.
If it's the part of the car that the x-mem bolts to, the car is pretty much toast. It is inconceivable that just that one spot has rusted bad enough to fall apart like that, but the rest of the car HASN'T. Impossible.
Same for the X-member... you haven't been driving around in the salt, and the whole car staying free of it except for just that one spot. You can bet that if THAT has cancerized completely through, you can see through the floor pan, the gas tank is less than a sheet of paper, the rear wheel wells probably are only held on by the carpet that's glued to them on the inside, etc.
Consider it a warning that it's time to SERIOUSLY inspect the car for rot, and prepare to buy another chassis.
Old Aug 23, 2011 | 03:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
seen this happen before, the frame section rots off and drops the trans. If thats the case, like sofa said, the car is most likely rotted badly elsewhere and may be a goner.
post pics of the underside!
Do not drive the car in this condition.
Old Aug 23, 2011 | 04:10 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Oh my that sir is not good, get some pics up...
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
theshackle
Aug 23, 2015 03:49 PM
