Torque Bar Installation
Car: 1983 Trans am ws6
Engine: 305 HO
Transmission: wct5
Yah im definetly an idiot I didnt read like I should have and removed the torque bar without removing the rear coil springs like I should have. Now the rear end is pivoted upward and the springs are tilted as well and about to fly off. what is the best way to get the rear end back to where it should be so i can get that torque arm on. thanks, Eric
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Torque Bar Installation
if you put a floor jack under the back of hte axle, lifting by the cover area, you should be able to get the axle to rotate down in the front. if not, put a jack stand under the panhard mount on the axle sice mount (driverside) and lower the rear onto that jack, that shoudl also rotate the front of the axle down, hopefully enough to get the torque arm back on.
FWIW, you may be able to just grab the front of the pinion and pull it down....
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Or you can pull the emergency brake and have a buddy push on the back of the car.. Or push it yourself then chock the wheels.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Or you could lift the front of the car and put it on stands. I've removed and reinstalled the torque arm several times while the front of the car was up on stands and never had a problem reattaching it to the rear axle.
Engine: 4++,350 & 305 CIs
Jackup the rear of the car and put stands under the rear subframe rails.
let rearend hang.
Grab a nylon ratchet strap.
hook a end to the panhard bar attachment point on driver side rearend.
wrap it around the frame tie bar.
hook the other end to the same panhardbar spot you did b4
B sure you put strap so u can work the ratchet.
now tighten the strap until the rear is rolled/moved into position.
Do it all the time, Works great.
let rearend hang.
just disconnect the rear shock mounts and lower the axle enough that you don't have any spring tension (watch the brake lines). The springs are what is causing the axle to try to rotate.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Dialed_In
Aug 20, 2015 01:45 PM
