Power steering Gear Box
Old Sep 4, 2011 | 12:52 AM
jlex300's Avatar
Car: 1987 IrocZ28 350
Hey guys,
New to the site. I just recently purchased a 1987 irocz28 350 engine.
I need to change the power steering gear box, but was told there are 2 different boxes and I would need to know what suspension is in the car. Problem is the cars rpo code is no where to be found. The 2 autopart places that I called said that I would need to know if its the FE2 or F41 suspension before I could put it in. I have tried in vein to figure this out threw google searches, reading forums and by calling a GM dealer where I live to see if they could run the vin. They say the car is to old. I need to get this done asap and cant till I find out this info. Does any one else have this car and know 100% about the suspension?
Thanks guys appreciate any imput.
Old Sep 4, 2011 | 06:57 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Power steering Gear Box
Welcome to TGO, jlex.
The IROC would be FE2. You can swap in any box you desire. Here's some general info (I'd like to give credit, but I don't recall where I found the info):
• “WS” – 1982-1992 Camaro – 12.7:1 ratio (just like your Z/28, this may be the box that you Z originally had.
• “XH” – 1985-1992 Camaro – 12.7:1 ratio (this box was also installed on Z/28’s and other high performance Camaros; it has slightly more steering effort required than the WS box.) NOTE – I believe this box was used on cars originally equipped with 16” wheels
• “WN” – 1982-1985 Camaro – 14.1 ratio
• “WP” – 1982-1985 Camaro – 13:1-15:1 variable ratio (used in Berlinettas, least steering effort required of all third gen. Camaro steering boxes)
• “JL” – 1986-1992 Camaro – 14.1 ratio (base Camaro steering box)
Info on FE2, etc. (a search will find more, should you be interested).
https://www.thirdgen.org/forums/susp...-fe2-help.html
JamesC
Old Jan 5, 2012 | 08:57 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
another question along the same lines...
if I have the JL steering box (and it's leaking) is there any reason I can't swap in a XH box?
would the hoses mount up the same way? any reason NOT to do it?
Old Jan 5, 2012 | 09:58 AM
JamesC's Avatar
No.
Yes.
No.
JamesC
Old Jan 5, 2012 | 09:59 AM
58mark's Avatar
ok, thanks
Old Jan 7, 2012 | 03:10 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
What about the "Z" box what years did these come on? I have a few sitting around all of them are 2.25 turns lock to lock...
Old Jan 11, 2012 | 03:00 PM
58mark's Avatar
I think they are ALL Z boxes. the difference is on the inside, not the stamp on the box
Old Jan 11, 2012 | 03:56 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
JamesC
All my Formulas and WS6 T/A have the same "XH" steering boxes as the camaro.
Old Jan 11, 2012 | 07:00 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
How about this steering box 7819679 L.H. THDH S 3A010CC 605 this is everything on this steering gear case-1983 Camaro
Old Jan 22, 2012 | 11:34 AM
racewrench's Avatar
Car: 1992 Camaro RS
Engine: 305 (406 swap coming)
how do I identify which box i have?
Old Jan 21, 2020 | 09:47 PM
zaxanllc's Avatar
Car: 86 Firebird TA
Transmission: Automatic
Axle/Gears: Stock POSI
Has anyone here done an electric power steering system conversion?
Old Jan 21, 2020 | 10:58 PM
Drew's Avatar
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
InfinityShade
Aug 22, 2015 08:00 PM
