sway bar bushing size
Old Sep 7, 2011 | 12:41 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Does anyone know what size bushings the sway bar takes on the end links and frame part of a 89 iroc with a 9 bolt rear? While I have it off I would like to go ahead and get those good red ones you see for the front and back but I don't know what size. Someone needs to list what years had what size bars.
Old Sep 7, 2011 | 06:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: sway bar bushing size
Someone has.
https://www.thirdgen.org/forums/faq-...-sway-bar.html
The problem with 'lists' is that our cars are old enough that what they were originally equipped with may not be what they're equipped with now. At the very least I'd measure to verify.
JamesC
Old Sep 7, 2011 | 07:13 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Definitely measure! The size differences are only 2mm, make sure to get gunk/rust buildup off before measuring sway bar diameter. End links are same standard size front and rear, and on the shelf at Autozone for same as internet prices.
J-money
Jan 4, 2019 09:45 AM
Linson
Sep 21, 2015 01:08 PM
timonator
Sep 10, 2015 07:55 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
