Spring and Shocks
Old Aug 30, 2011 | 03:21 AM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Spring and Shocks
Looking to upgrade whats the best combination of these two? And what are you currently running for these two?
Old Aug 30, 2011 | 07:08 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Spring and Shocks
Best is always subjective. That said, I'm running Moog IROC replacements and Koni Reds.
JamesC
Old Aug 30, 2011 | 07:24 AM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
JamesC
That is true guess the question i should really ask is what does everybody have and what have they had and how were they
Old Sep 3, 2011 | 07:12 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
what do you plan to do with the car? are you concerned with straight line performance or cornering?
Old Sep 3, 2011 | 08:02 PM
92Firebug's Avatar
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
Moog front and rear...and KYB AGX's to top it off (KYB's are sweet and cheap shocks/struts)
Old Sep 3, 2011 | 08:11 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Itll be my daily driver but would like to be able to take a weekend out to a strip
Old Sep 4, 2011 | 08:47 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
I'd go with Moog springs and KYBs then. Not worth the money for Koni shocks if you're not serious about cornering. Do a search on the moog springs, there is a lot of info on them here..
Old Sep 4, 2011 | 10:34 AM
jrz28's Avatar
Car: 1984 Berlinetta
Engine: 305 Carb
Eibach Pro Kit and Koni reds.
Old Sep 4, 2011 | 11:03 AM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
x2
im running the yellows and like the adjustible option, not sure if the red is adjustible or not.
eibach pro kit is great, the roads where i live suck big time and have no issues. if the pro kit is not low enough you can always remove the insulators and use a heater hose.
Old Sep 4, 2011 | 11:18 AM
dubbuzz's Avatar
Car: 1986 Camaro Berlinetta
Engine: 5.0 305 4bbl LG4
Transmission: AT 700R4
Axle/Gears: 2.73 Posi
I'm running on cc635 rear springs which are IROC OEM replacement spring except they are from autozone but they are the same exact thing as the moogs only half the price. I have Gabriel HiJakcer air shocks in the rear filled to 60 psi to boost my car over my wide tires. I have Gabriel Ultra front struts and still have the stock front springs. The car has a little bit of body roll while turning because of the variable rate coils in the rear but I am really happy with how it rides.
Old Sep 5, 2011 | 06:55 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
i run KYB AGX + Eibach Pro-kit and they do the job for daily drive, goin' track/strip? just adjust shocks and you'r ready to race
best regards
Old Sep 5, 2011 | 02:46 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
I agree with this 100%. No sense in wasting money on pricier items for no reason.
Old Sep 5, 2011 | 09:51 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
if you love cornering pro-kit, koni yellows and good tires..... that would make a world of difference..
Old Sep 7, 2011 | 02:09 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I have looked at allot of threads and for a Daily Driver and Ive decided to go with the Moog 5662 front springs with KYB GR-2 struts, and Moog 5665 rear springs with KYB Gas-A-Just rear shocks. Hoping to get a nice firm ride,with out breaking the bank.
Old Sep 7, 2011 | 02:45 AM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Leaning towards this as they seem to have good reviews and have been suggested to me a few times let me know how it rides thanks
Old Sep 7, 2011 | 11:30 AM
88fastgta's Avatar
you might want to look at how high a car sits with those springs.... i had those same springs correctly indexed and i hated the look.. waaay too much fendergap.... so i went with the prokit and couldnt be happier
Old Sep 7, 2011 | 01:15 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
The moog springs need to be cut, you are looking at a minimum of 1/2 coil front 3/4 rear. The good news is you get a little more spring rate out of them that way.
Old Sep 7, 2011 | 02:26 PM
Engine: TBI,5.0
I know this is not my thread but am hoping the OP dose not mind me asking questions. It seems that we both are working towards the same goal. It would be nice to see a car with the uncut Moog springs (side shot if possible)
Also do you need a alignment after replacing front struts ?
If not ,do you need a alignment when replacing front struts and springs ?
Old Sep 7, 2011 | 07:33 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
I have replaced struts and not done an alignment as long as the car was lined up correctly to begin with you'll likely be fine. In theory you could lower the car and not change the alignment(depending on how much you lower it), but I've not done that. You should at least have the toe checked after you lower it just to be sure. Double and tripple check your idler arm and center link for wear as these items seem to take the most abuse. If they are worn and need replaced you CERTAINLY need a re-alignment.
Pac J
May 17, 2020 10:44 AM
92projectcamaro
Dec 8, 2015 12:25 AM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
