what do i need to mount a rear sway bar
Old Sep 19, 2011 | 12:42 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
So the story is a bought this 91 formula 350 3 months ago. it has a beefed up 373 rear end in the car but no rear sway bar. I need to know which sway bar to get and what mounting hardware do i need. will the 24mm rear sway bar work with my rearend? any help would be great.
Old Sep 19, 2011 | 01:28 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: what do i need to mount a rear sway bar
If I recall, you will need U bolts and brackets for the bushings that attach to the axle tubes. The bushings themselves can be bought new for cheap.
The end links can also be bought aftermarket, and thier attaching holes on the body (near the shocks) are likely already there.
Old Sep 19, 2011 | 07:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A kit, as well as the, end link mounts, can be found at the site below:
http://www.top-downsolutions.com/cha...d7da23256249f9
The 24mm bar accompanied the 34 and 36mm bar. While the bars came in sets from the factory, you can mix and match for your own purposes.
JamesC
Old Sep 19, 2011 | 11:24 PM
Car: 91 formula
thanks fellas
Old Sep 20, 2011 | 08:22 AM
UMI Performance's Avatar
We offer a sway bar mounting kit as well. It includes heavy duty brackets, U-Bolts and end links. Below is the mounting kit we have to offer. If you have any questions please ask.
http://www.umiperformance.com/catalo...roducts_id=322
Thanks!
Ryan
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
z28addict8490
Aug 7, 2015 08:48 PM
