Strut Tower Brace
Old Sep 22, 2011 | 02:34 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Strut Tower Brace
Does anyone know if the brace will clear the Holley Stealth-Ram on a Vortech set up in a 91 Z? any help would be greatly appreciated
Old Sep 22, 2011 | 03:09 PM
Twin_Turbo's Avatar
Re: Strut Tower Brace
What brand? Don't think any of them clears, the edelbrock and BMR ones won't most likely. BMR has more clearance than the edelbrock one.
Old Sep 22, 2011 | 04:19 PM
91 Droptop's Avatar
Have not really looked at brands, that is what I was wondering about if any could clear the Ram
Old Sep 22, 2011 | 04:20 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
The TBI brace from Edelbrock might...
Old Oct 21, 2011 | 07:44 PM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
I know for a fact that the Edelbrock TPI brace won't fit without modification or stock hood...got one as part of a package deal with subframe connectors. The brace hits on the throttlebody and stut mounts sit about 3-4" above the strut tower. I'm trying to decide if I should modify or sell it. I have a ram air hood, so if I mod it I think it'll clear the hood....need to do some mock up and measure to be sure about the hood clearance though.
Old Oct 21, 2011 | 08:06 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
my bmr strut tower brace worked nicely for my old Gm tpi but when i put the First fuel injections tpi on there it didnt fit anymore so i had to make 1 inch plates for it to barley clear the plenum... the brace just misses the hood by a hair but it all works... from what i hear the HSR fit even higher than the first intake so i dont think you will be able to use the strut tower brace anymore... thats was one of my reason not going with the HSR...
Old Oct 21, 2011 | 09:24 PM
platynumx's Avatar
Car: 89 rs vert/88 t/a GTA
Engine: 355 tbi/350 tpi
Transmission: 700r4 w/megashifter/700r4
Axle/Gears: 3.73/???
dunno if it helps but heres a (crappy) pic of tbi strut tower brace .my car is tbi. i ll get better pic tomorow if it helps with anything
Old Oct 22, 2011 | 11:28 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
No, none of the aftermarket ones will clear a stelth ram, without mods.
Better off building one yourself.
Old Oct 22, 2011 | 12:00 PM
91 Droptop's Avatar
Well I do have a fabricator/welder at my shop, I am sure he could build one. Does anyone out there have one made already? this would cut down on time if I had plans to go by
Old Oct 22, 2011 | 06:02 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
The BMR won't fit with a stealth ram unless you modify the hood. I wonder if the UMI piece will fit with a stealth ram using either aftermarket strut mount or some sort of strut mount spacer.
I have the BMR with stealth ram combo and honestly i don't like visually how the BMR piece fits.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
