Pitman arm questions
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Hey got a few pitman arm questions and a complaint. The complaints to summitracing.com who sold me the pitman arm thats NOTHING like the one on the car, even though they said it would fit.
Anyway so can i use a used one from crqigslist or something? Do i gotta buy a new one?? They arent cheap but used seem very reasnable.
And while im at it how do you replace it? It wasnt easy comming off.
Thanks for any help
Thanks for any help
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Pitman arm questions
JamesC
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You could have had worn out tie rod ends, idler arm or center link. Maybe even a worn out steering box but it's highly unlikely the pitman arm itself is bad unless it was damaged in an accident. It's a big piece of steel bent into a double elbow with 2 holes in it. Nothing to wear out.
To remove it from the steering box, you need a pitman arm puller.
Earlier cars like first and second gens have the ball socket as part of the pitman arm and that does wear out. Third gens have the ball socket moved to the center link so there's nothing on the pitman arm to wear out.
ambainb
Apr 25, 2016 09:21 PM
