Are All 3rd Gen Disc Rear-Ends Posi 3.42's?
Old Oct 17, 2011 | 08:26 AM
MacsIROCZ's Avatar
Car: 86 Iroc-Z28 Camaro
Engine: 383 SB
Transmission: TH350
Axle/Gears: Stock disc brake 3.43
I am swapping out my drum rear-end for a disc rear-end out of a 89 Irocz (or may just be a regular Z) parts car... Do they all have the same 3.42 gears and are they posi?
"Sorry for the dumb questions just trying to get my feet wet before I jump in the pool" Thanks guys
Old Oct 17, 2011 | 08:36 AM
Twin_Turbo's Avatar
Re: Are All 3rd Gen Disc Rear-Ends Posi 3.42's?
no, 9 bolts and 10 bolts, different ratios available.
Old Oct 17, 2011 | 11:35 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Disc or drum has no bearing whatsoever on what gear ratio it has.
Old Oct 17, 2011 | 11:56 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
nope, you could have a disc rear with any ratio available in that given year. My 83 had a factory disc rear with 3.23's in it.
Old Oct 19, 2011 | 12:41 AM
83 Crossfire TA's Avatar
My '87 had a 9 bolt with 3.27 and disks...
Old Oct 19, 2011 | 01:06 AM
_MIKE_P's Avatar
Car: 1984 Z28 / 2001 Maxima SE
Engine: L69 / VQ30DE
Transmission: T5 / Auto
'84 Z28 with discs and 3.73's here. No posi however
Old Oct 19, 2011 | 06:25 AM
MacsIROCZ's Avatar
Engine: 383 SB
Transmission: TH350
How did you guys find your gear ratio? Also, My fab mechanic mentioned a limited slip posi the other day? now he is kinda an older guy who has been through many years of logging but the man is a race-car builder! A DAMN GOOD ONE! but is there such a thing as "limited slip Posi?" (and yes I know drum vs. disc makes no difference on gear ratio!)
Old Oct 19, 2011 | 08:46 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Jack up the rear end off the ground & support it by jackstands.
Put the tranny in Neutral & from under the rear of the car, rotate a tire by hand & watch the pinion/driveshaft rotate.
Count the pinion/driveshaft rotations for 1 tire revolution & you'll get your gear ratio.
For a 10-bolt:
If the pinion/driveshaft rotates 3 times for 1 tire revolution? You have a 3.08.
If the pinion/driveshaft rotates almost 3 times for 1 tire revolution? You have a 2.73.
If the pinion/driveshaft rotates almost 3 1/2 times for 1 tire revolution? You have a 3.42.
For a 9-bolt:
If the pinion/driveshaft rotates almost 3 1/4 times for 1 tire revolution? You have a 3.27.
Those are not the only ratios out there, but also are some of the most common that you'll find. Your IROC might have the 9-bolt/3.27 or 10-bolt/3.42, but after all these years, no telling if a previous owner has swapped it out after all these years. My daughter has a 1990 RS with a 1984 10-bolt/3.73 posi with aluminum drum brakes, all factory stuff from 1984 Z28 that I put in her car.
Old Oct 19, 2011 | 08:50 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
My '83 has a 10 bolt posi with 2.93 gears. My '89 has a 9 bolt posi with 3.45 gears. Both are disc brakes.
Old Oct 19, 2011 | 09:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
...is there such a thing as "limited slip Posi?"
The following should be helpful or at least provide a general idea:
https://www.thirdgen.org/forums/tran...-10-bolts.html
Limited slip = posi
JamesC
Orr89RocZ
Apr 25, 2016 08:28 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
