bmr conectors and relocation mounts
anyone know if the bmr relocation brackets will work when you put on their subframe connectors ( weld on)?
i want to buy the drag race package (part num drp003) but not sure if this package will work if i use their weld on frame connectors (prt num sfc009)
are the relocation brackets part of the subframe connectors or do the relocators bolt over top of the connectors?
(hope i make sense here)
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: bmr conectors and relocation mounts
you have things confused. the control arm relocation brackets install on the axle side of the control arm, not the body side where the SFC's attach. They will all work together just fine
Like Phil mentioned the SFC's will mount to the chassis side of the car while the relocation brackets will mount to the rear end side. They will work together with no issues.
If you are shopping around and looking for other options we would be glad to help you as well. We can offer the same kit at the same price.
If there is anything I can help with please ask. Thank you!
Ryan
Ryan
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
