founders lcas and panhard bar
Old Oct 18, 2011 | 12:06 AM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
im looking at getting this kit for my 92 z28.
http://www.foundersperformance.com/p...B47%7DRod.html
i mainly dd this car with lots of spirited corner carving and autocross events. ive read before that that lower control arms with the solid ends like these are better for autocrossing thats why i want these BUT if anyone has any other info im all ears. i found out i have to drop my gas tank to fix a leak so while its apart ill do these and some lcarbs at the same time. just looking to see what others think.
Old Oct 18, 2011 | 08:26 AM
UMI Performance's Avatar
Re: founders lcas and panhard bar
For a daily driven vehicle you main want to consider control arms and panhard bar that have polyurethane on one end to help absorb some the road shock. The rod end/rod end set up like above will work great for autocross but might be a little noisy on the road. I would recommend a poly/rod end or poly/roto-joint combo for a daily driver car, they would be quieter and less harsh.
I hope that helps!
Ryan
www.umiperformance.com
Old Oct 18, 2011 | 12:59 PM
Screamin86's Avatar
noisy as in transfering alot of road noise through the body i assume. well i guess i should be more specific i usualy only drive the car twice a week and my daily driving totals to about 5miles if that lol. thanks ill look into both of those other setups too.
Old Oct 19, 2011 | 07:35 AM
Yes, as in transferring more noise. A rod endede set up that uses rod ends on all ends eliminates the rubber bushings completely and there is now nothing soft to absorb the shock. So performance will be good but you might want to look at a less aggressive set up for street use. Below is a sample:
www.umiperformance.com/201621
Thanks!
Ryan
Old Oct 19, 2011 | 12:14 PM
Screamin86's Avatar
thanks again
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
