Is there a difference?
Old Oct 31, 2011 | 09:44 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
I'm replacing all of the front brake hardware including the rotors, bearings, and seals. I run up to Napa and pick everything up based on what their computer specifies for my 91 z28. I get home and the outboard (smaller) bearings don't fit in the new rotors, they're too large to properly fit the already installed race. A Sunday trip up to Napa finds the "B" team behind the counter and with no dicernible results, I leave her my name and number and ask that they get to the bottom of it and call me back. Fast forward to today. Having just spoken to the "A" team at Napa, he tells me that GM put "RS" spindles on my car which is why the "Z28" bearings won't fit in the rotors. He goes on to tell me that GM would use parts from other models rather than shut the line down to wait on the correct part....having worked at an assembly plant, I completely understand.
However, I don't recall, and for that matter don't understand, why GM would spec two different spindles for a Z28 and an RS. Rotors, calipers, etc aren't different(excluding the 1LE), why would the spindles be? I think he's feeding me a line. Thoughts?
Old Oct 31, 2011 | 09:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Is there a difference?
There are two spindles: standard and 1LE (the only difference there is that the 1LE spindle has its ears cut off to accommodate the larger brakes). IIRC, the inner bearing is the same for both, only the outer bearing is different with the 1LE being larger.
EDIT: The A6 inner bearing is common to both the standard rotor and the 1LE. The A3 outer bearing, which the 1LE uses, has a larger OD than the standard A34 bearing. If you had the larger bearing, you had the 1LE.
JamesC
Old Oct 31, 2011 | 10:06 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
So NAPA must have the 1LE specification for the outer bearing as a default listing. The smaller of the standard vs. 1LE will fit 99% of third gens, independent of model. Concur?
Old Oct 31, 2011 | 10:13 AM
JamesC's Avatar
Yes.
JamesC
Old Oct 31, 2011 | 10:16 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Thanks for your timely response.
69GTOby
Apr 18, 2016 02:34 PM
scottmoyer
Sep 20, 2015 11:54 AM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
