Strut brace for HSR
Car: 1992 Z28
Engine: 388
Transmission: 4L70E
Strut brace for HSR
Looking to install a strut brace but have been told my HSR manifold will be a problem. Does anyone make one that fits my 92 Z28 and HSR?
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: Strut brace for HSR
very good question im going to need this as well for when i get my hsr set up for my 355 sbc
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sorry, I can't answer your question. That said, if you haven't already, you might consider after market strut mounts with spherical bearings before or in conjunction with a future STB.
JamesC
JamesC
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
i have been looking for awhile for one. no luck, alot of people build there own but then your hood clearance is an issue. a cowl hood or a raised hood is a must because the stealth ram sits at least an inch or two higher then the tpi or tbi.
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
I have seen pics of a custom made STB that fits. None that you can buy from a manufacturer is going to fit.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I've seen a pic with a car that had an HSR and a Hotchis STB.
Car: 1992 Camaro
Transmission: t-5
Mine is extremely close. The clamp on the intake dented my hood.
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
LT1Formula
Oct 8, 2015 08:34 PM
tcflint
Sep 27, 2015 05:58 PM
