opinions: subframe connectors
Old Dec 21, 2011 | 04:46 PM
ol' paddy's Avatar
Car: 1992 RS
Engine: 94 LT1
Axle/Gears: 10 Bolt 3.42
I'm wondering if subframe connectors would improve my suspension setup greatly,(if they're worth the $200?
The car will be my daily driver but i will definitely autocross it a good amount.
my current set up is:
bmr adjustable panhard
bmr lowering springs 3 in 300lbs rear 400lbs front
weight jacks
all poly bushings
6 pt. welded roll bar
looking for opinions on this. are they worth it.?
Old Dec 21, 2011 | 05:12 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: opinions: subframe connectors
Yes they help...
I have the Spohn ones that are great... They are round, and tuck up nice under my Formula, hard to see... some of the boxed ones can be seen / are more visible from the side of the car...
I had a horrible experience with Spohn A Arms, and as a result, I'm not buying anything else from them...
I would also get aftermarket rear lower control arms and if you're having traction problems because of the lowering, relocation brackets for those too... I kept mine stock height, added wonder bar, strut tower brace and you can feel the car is a lot more stiff than stock...
Rafael
Old Dec 21, 2011 | 06:13 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Do you have a T-Top car? You iwll feel a dramatic improvement in stiffness.
Do you have a hard top car? You need sfc's to keep that window corner crack from spreading and growing.
Old Dec 21, 2011 | 07:13 PM
ol' paddy's Avatar
Car: 1992 RS
Engine: 94 LT1
Originally Posted by luvofjah
Yes they help...
Rafael
how is the ground clearance on the connectors? if they hang down lower than the exhaust then i probably shouldn't use them yet... my cars already doesn't agree with any speed bumps.
the car isn't running yet but i have the gas tank out cause of the rollbar installation and i figure any weld in suspension upgrades i'd feel better doing with no tank in the car.
how about the wonderbars? the cars an rs and the spohn one is pretty cheap, or is spohn generally seen as bad, i've heard really bad things about their tranny crossmembers and such.
Old Dec 21, 2011 | 07:22 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Get sfc they will help tons best mod u can do wonder bars help too reason why they are called a wonder bar
Old Dec 21, 2011 | 09:05 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Yes, SFC's help, but with a 6 pt weld in cage I don't know if you need them. I have the Alston's and clearance is no problem. My car is not lowered though.
Old Dec 21, 2011 | 11:56 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Mine is lowered and I have never had a problem with them. You can see em from the side though. My long tubes are way lower than the sfc . Makes for a bigger jacking point too.I have umi ones in red id go blk next time which would get em to blend in.
Old Dec 22, 2011 | 08:10 AM
UMI Sales's Avatar
Hey guys.
The six point cage should tie things together pretty well but SFC's are cheap insurance.
We have an in-house '85 IROC with all our goodies installed. It's like driving a slot car.
We have our Christmas sale starting tomorrow (23rd) through the 28th. That would be a great time to pick up a set of SFC's at a great price.
ramey
Old Dec 22, 2011 | 05:55 PM
irocarter's Avatar
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
I'm running the jegs brand SFC and I had to screw a 2inx2in 1/4in piece of rubber onto the passenger connecter to keep the factory dual cat ypipe from bangin' and clangn'.Other than that,major improvement.
Old Dec 22, 2011 | 09:21 PM
ol' paddy's Avatar
Car: 1992 RS
Engine: 94 LT1
okay, thanks for the info, i think for now i'm going to go for a wonderbar and some relocation brackets.
Old Dec 27, 2011 | 08:58 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I have Hotchkis SFC's in my iroc from the two owners ago or there abouts. Ive driven third gens without and then this one and i can honestly say this is the most solid riding car third gen ive been in because of the SFC's i think. It really pulls the car together and firms it up. Id go for a set. As for ground clearance you cant tell its got them because they dont really hang lower than the pinch welds. Just watch out for Y-pipe clearance. I had to modify my y-pipe so it didnt hit the passenger side connector.
Old Dec 27, 2011 | 10:26 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i have alstons and bmr subframe connectors together in my car..... you should take a look at my thread... lots of good info with pics..
https://www.thirdgen.org/forums/susp...-subframe.html
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
