spring compreesor tool?
Old Dec 25, 2011 | 10:20 PM
irocdls1's Avatar
Car: 88 Iroc ls1 swap
Engine: ls1
Transmission: 4l60e
Axle/Gears: original disc
i was putting new a arm bushings in my 88 iroc... but dont know what spring compressor to use can anyone help me....????
Old Dec 25, 2011 | 11:23 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Re: spring compreesor tool?
You can pick one up at your local auto parts store
Old Dec 26, 2011 | 03:38 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
None of those parts store compressors worked for me. I dont thnk I've seen anyone on here say they used one successfully either.
You're better off with a long crowbar and a floor jack.
Old Dec 26, 2011 | 06:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Pic #5 of the link below shows a pic (along with the pipe nipple you should use). I've employed it several times without issue. One can be rented from Autozone. As always where springs are concerned, safety first. I'd chain the spring in place regardless of the removal method.
https://www.thirdgen.org/forums/susp...nt-spring.html
JamesC
Old Dec 28, 2011 | 04:21 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
ive always used a floor jack. If you have lowering springs it makes it easier than stock ones as the jack will take the complete load off the spring and will just drop out. Ive done it a few times on my car with a eibach pro kit
Old Dec 28, 2011 | 05:24 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
The type I used was the long bolt with the 4 hook / clamps... you put it inside the spring, set the hooks, and start tightening the bolt.... I did have to cut / shorten the bolt because the way it was was too long (read that here too) but worked great...
Rafael
Old Dec 28, 2011 | 09:35 PM
84ws6ta's Avatar
Car: 1984 Trans Am
Transmission: JW Performance 700R4
Axle/Gears: Borg Warner 9-bolt, 3.08 gears
I used an internal compressor made by OTC. It uses plates and a thrust bearing which made compressing the spring very easy. They're not cheap though, cost me $175 but well worth having the proper tools on hand. Most of the part store compressers don't hold position well and are hard to compress because it's just metal to metal contact creating increasing friction as you tighten.
Ed1LE
Sep 30, 2018 09:14 AM
92projectcamaro
Dec 8, 2015 12:25 AM
Reid Fleming
Oct 10, 2015 09:56 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Dragonsys
Sep 25, 2015 03:51 PM
