installed rear springs and they fell out
Old Jan 9, 2012 | 11:21 PM
imRICH23's Avatar
Car: 88 vert iroc & 95 586hp trans am
Engine: 355
Axle/Gears: 373
well not all the way, but they moved over to where i can takethem out.. im talkin with thecar jucked up and rear hanging... do i need a special shock or is this normal?
Old Jan 9, 2012 | 11:26 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: installed rear springs and they fell out
If they moved, they were lowering/cut springs. A stock spring should still stay seated & at "worst", be able to be fairly easily pried out with the shocks still connected. Loosen the shocks & the rear axle will drop lower & possibly get even a stock spring to come loose.
Old Jan 9, 2012 | 11:31 PM
imRICH23's Avatar
Engine: 355
Axle/Gears: 373
I'm sorry.. they are lowering springs. On my truck with rear lowering springs they make lowering shocks, just wasn't sure if it was the same for the camaro.
Old Jan 9, 2012 | 11:40 PM
Car: GTA
I've considered getting some Limiting Straps made for my car. The shortest I can find are for 4x4s & twice as long as I need.
Old Jan 9, 2012 | 11:47 PM
imRICH23's Avatar
Engine: 355
Axle/Gears: 373
So this is normal?
Old Jan 10, 2012 | 05:07 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Normal.
Old Jan 10, 2012 | 12:34 PM
TransAM Joe's Avatar
If you ever see a MSE or Macho Trans am in the bone yard they will have limiter straps, I took the ones off the rear of mine(rear is gone now), I'll see if they are in a box somewhere in the shop.
If not I have a contact who might.
Old Jan 10, 2012 | 12:42 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
so you can't be jumping the creek with it like bo duke after lowering it ... noted lol
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
