worth replacing track bar?
Car: 1991 CHEVROLET CAMARO Z28
Engine: 6 LITER after rebuilding :)
Transmission: 700 R4
Axle/Gears: 3.23 / 9:7:1
I have overhauled almost all suspension components but this is an OEM restoration/replacement and not an upgrade. Track bar does not have replacable bushings (or so it seems to me) so how much of an improvement will I see if I were to replace the track bar altogether? Thanks in advance for your opinions.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: worth replacing track bar?
Even at stock height on stock wheels, stock sized tires & a stock PHB (Panhard Bar - what you termed Track Bar), my rear end housing was offset to the drivers side by almost a full inch. I never noticed until I put 17" wheels w/285 tires on. Then it was pretty obvious.
OK thanks for the reply but as I am not too experienced in suspension, what is your advice?
Car: GTA
If you are still on stock wheels & tires, you can use a plumb bob (washer tied to a string works just fine) hanging off the side of the quarter panel will tell you where your rear end is. Compare the 2 sides & you'll know if yours is off center or not. Then you will know if you need a APHB or not. And honestly....If it is just s driver & not "raced", then you don't need one. I only needed one in order to fill my 11" wheels w/315 series tires. This is my 6th(i think) 3rd gen which included 2 that were almost autocross-only cars & I didn't have one on them. Would have helped a tad I'm sure, but I didn't. I didn't NEED to.
Like this:
Like this:
ok thanks much for the info...
Car: RS
Axle/Gears: 9" for the ladies
I have an aftermarket track bar(the upper bar) that bends down lower then stock (right side of pic) to allow dual exhaust to run up over it if a person wanted.
Lower bar is panhard bar and you can see how an aftermarket one is adjustable.
I wouldn't worry about sticking out different amounts on each side. My problem was rubbing with wider tires on the inside. That's what I adjusted for.
On a stock car neither should reall be a problem.
Thanks for the input however I must mention that the nomenclature is rather different in the rock auto parts: Sway bar is the U-shaped one (on which bushings are replacable) and the Track bar is the straight one (on which bushing are NOT replacable). I am talking about the Track bar as I am concerned with the quality of the non-replacable bushings since they are on it since 1991.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the track bar is also called a panhard bar.
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 5, 2015 07:57 PM
