Weird noise after strut and mount replacement
Old Jan 21, 2012 | 08:31 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
This morning I replaced both my struts and strut mounts, both were the originals and shot, well after I got them on I went for a test drive and whenever I hit a bumb or something my driver side strut sounds like its hitting something metal on metal and idk what it could be, it rides alot better and doesn't seem to move or anything but it's just a noise that I don't like or know what could make it. Any ideas?
Old Jan 21, 2012 | 10:56 PM
Engine: L31 350
Re: Weird noise after strut and mount replacement
bumb
Old Jan 21, 2012 | 11:07 PM
85irocinjected's Avatar
Car: 1991 RS
Double check that everything is tight. Go back over everything with wrenches.
Old Jan 22, 2012 | 04:59 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
It's probably the big nut on the top of the rod. Easy fix - tighten it with the weight of the car on the wheels. Best way to do it is with a hammering air gun - but make sure you do it in short bursts. If you spin the rod too much it will heat up the rubber seal and damage it.
Old Jan 22, 2012 | 07:57 AM
Engine: L31 350
I used an air rachet and adjustable wrench yesterday to tighten it up, I'll go back over it today though, just have to figure out how the dust cap comes off
Old Jan 22, 2012 | 08:15 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The plastic cap simply pries off.
JamesC
Old Jan 22, 2012 | 09:12 AM
Engine: L31 350
Yeah I got it, driver side nut was really loose. It's all tight now
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
TheExaminer
Aug 25, 2015 07:34 PM
