Loud Mysterious Noise after Highway Driving?
Car: 1988 Trans Am GTA
Engine: 5.7 TPI
hey guys, I have a problem with my GTA, whenever I get off the highway after long trips. It especially happens after long mountain highways where there is a lot of curves. for example Vancouver to Whistler, if anyone is familiar with that route.
anyways, the sound only occurs when I pull off to the side of the highway and do city driving. and even then it only lasts until I park the car. I am very confused by the noise wondering if anyone can help me out.
I mostly happens when I am turning. sounds like a terrible creaking metal on metal sound but it doesnt effect the drive at all, i Just hear the noise.
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Loud Mysterious Noise after Highway Driving?
Sound like something flexing in the front of the car? Near the strut towers?
Engine: 5.7 TPI
it defintitly seems to be coming from the front, ya
Engine: L31 350
sound like flex? If it is, I'd say it's your strut mounts or struts, had a similar. Ouse but everything was tight, came to find out both struts were shot and my driver side strut mount was shot and allowing the strut to move and flex while turning or hitting a bumb. If at from the strut areas I'd replace those
Engine: 5.7 TPI
that sounds like it could be it, but why would it only happen after long trips at higher speed
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I think I'm dealing with something similar. Just get a strange noise while turning the wheels left/right at a stop or at low speeds after driving it a while. Weird creaking type sound.
Did you ever figure it out? Like you, it doesnt do it early on, just after a medium/long drive.
A LOT of my suspension components are pretty new. I've got new ball joints, new a-arm bushings, good sway bar bushings, wheel bearings are fine, struts are Konis that are 4 or 5 years old (they should be fine)...
Car: check
Engine: check
Transmission: check
Check the metal area around the steering box, where it bolts to the frame. Known issue that they crack there. Once repaired also install a wonder bar (steering brace).
RBob.
RBob.
Car: 1992 Camaro RS
I have a wonderbar already. Never noticed anything off down there.
Car: 87 iroc-z
Engine: 454
Transmission: th350
are you sure its not the rear? ive experienced all these symtoms on a few cars with lsd/posi. after a long drive, ill slow down for some city driving, take a tight turn and then start hearing some clunking noise. a few hours later or the next day the noise is gone.
Engine: 5.7 TPI
if you figure it out please tell me, I would love to know... I had two buddies in my car when it happened last time and they seemed to think it was coming from the very middle of the car, Driveshaft?! This problem is the bane of my exsistence...
Engine: 5.7 TPI
ok, so It did it again today. I had my buddy get out and listen. I drove back and forth very slowly..with the steering wheel straight, no noise. with the wheels turned in any direction going back and forth would make the rear wheels make a weird rubbing noise with a definite clunking. anyone? please?
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
Engine: 5.7 TPI
ya specifically the wheels or right behind the wheels (rear) only when the front ones are turned.
Car: 1982 Trans am
Engine: 383
Engine: 5.7 TPI
years probably, its very temperature dependant this problem. You may be on to something..
Car: 1982 Trans am
Engine: 383
Engine: 5.7 TPI
cool man, didnt even realize until now that u were from vancouverfbody
theshackle
Sep 17, 2020 08:26 AM
