Upgrading My Suspension, advice.
Re: Upgrading My Suspension, advice.
I was speaking of coilovers, i keep confusing the two. Thanks for the clarification.
The stiffer the better the handling right? but at what point for a street car do you compromise for drivability on the street.
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
As for streetability, its all in how its setup. If you set it up like my cousin's old integra...its gonna suck big time. He couldn't even do a K turn with his steering radius and he had coilovers. Now thats probably bec the PO before him didn't do it right. As 86TA says, 800+ lb springs in the front is not out of this world crazy. I think people are running 900s with ground control weight jacks with regularity.
I read somewhere they were closer to 650 stock. 550 in earlier cars. Pro Kit springs are 714 or so, Sportlines are lower than that. I know the pro kit is stiffer than stock both front and rear, by how much, seems to be up to debate because GM changed the spring rates so often.
Trying to find a nice medium, the roads arnt even, or designed for fast cornering like a track is, so finding a nice medium isnt easy to me.
Ive seen that issue too, suspension settings were too stiff on the street, ride was very uncomfortable and it didnt handle all that well.
Car: 89 Iroc
Engine: 305TPI
Springs for the Ground Control kit are dirt cheap. If you go with a 800-900lb front spring to start with and it is too stiff, just pull them off tuck them in a corner for a track event and order some softer springs. I can, almost, guarantee they will not be too stiff. As for the read anywhere between 175-250lb you will be good and shoultdn't need a softer spring.
Got my UMI CC plates the other day. Quality is great, but thats a given with UMI. Going to install them first chance I get.
Might be a stupid question, it did come with instructions but i still have a question lol.
So the little metal piece(the bearing/housing) is put on top of the shock stud, and the nut is threaded on but not tightened. Then you install the CC plate "housings" i call them as the instructions tell you to, THEN do you use the supplied harware to bolt that bearing housing to the CC housing?
sound lost dont i?
sound lost dont i?
sound lost dont i?
sound lost dont i?
When I install CC plates on project cars, I install the CC plate complete with the bearing housing and four 12-pt bolts. Leave the 12-pts loose. Compress the strut (it'll probably be extended) and allow the top of the strut to eject up into the hole. Then put the main nut on. Then align and tighten the four 12-pts.
Does that work?
thanks
ramey
HeyI ramey thanks for the response. That's exactly what I ended up doing. Getting ab alignment now actually.
Was very satisfied with the CC plates. Great quality on the products and the powdercoating was great.
Only thing left is
Konis
CC weight jacks
SFC
Bushing kit
And im pretty much done with the suspension side of it. Then steering. Then procharger
Only thing left is
Konis
CC weight jacks
SFC
Bushing kit
Only thing left is
Konis
CC weight jacks
SFC
Bushing kit
Only thing left is
Konis
CC weight jacks
SFC
Bushing kit
So the Konis are on there way.
Im going to purchase my GC weight jacks now and UMI SFCs.
For the weight jacks, what spring rate(front and rear) would you all suggest?
Want this thing to handle, but keep in mind i still want to be able to drive it on the street.
Car will mostly be used for canyon runs down south here in CA and some autocross events. So im willing to sacrifice some comfort for better handling.
Advice?
Also installed my CC plates from UMI a couple days ago, worked great, got an alignment cause i was way off lol. Ill have to get another when i do the shocks/weight jacks BUT its worth it. Had the shop pull half a degree of camber and caster(negative). Nothing too aggressive till the new shocks/springs are on.
will throw in pics tomorrow if it stops raining.
Advice?
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Sweet i was just at UMI today an picked up a few parts they even gave me an the wife a tour of the shop talk about a dream job, place has a great lay-out..
I think im going with 850 fronts an 200 rears should be a good set-up
shox.com has this set up on sale for 20% off. I just got mine.
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Last fall I got 4 Bilsteins (lifetime guarentee) and put the red polyurethane bushings on front and rear sway bars including the end links and Yokahama es 100 tires and it made a huge difference on my 92 Z vert. It had stock shocks, struts and completely worn out original bushings on both bars so the improvement was mind boggling. While I was swapping the stock rear out for a 89 327 9 bolt posi with pbr rear disc I also added a walbro fuel pump. I can jerk the steering wheel now and slide the car like a go-cart.
Bump, any info on the spring rates?
Little update.
Upgrading brakes to Performance Friction pads and slotted rotors. Currently running BrakeBest Select pads and rotors and ive managed to overheat the brakes on some hard runs. Ill take pics when i do swap them out.
Another question, ill be buying the UMI SFCs soon and want to know how difficult they are to install? I cant weld btw lol. Thinking of leaving this to someone who knows how. Advice?
Little update.
I'd consider 850/200 medium high spring rates. They'll definitely spring the car pretty firm. The trick is balance. You know you'll have a crisp ride. After you drive awhile you'll know whether the car is tight or loose (understeer or oversteer). If it oversteers, you can add front rate. If it understeers, you can add more rear spring. And so on...
Our SFC's are easy to install. You can even put the rear bolts in and slide the SFC's up into place. Then do all your grinding on weld tabs to save shop time. Then remove them and take them with you to the weld shop. Voila, less labor hours - a good shop might be able to stitch them in for 50 bucks...
ramey
Hey William.
ramey
ramey
Another question relates to steering. I have a little slop in the wheel, would it be worth swapping the steering box for a close ratio box or is that a little overboard?
Ramey thanks for all the input, soaking it all in. Think ill start with 850/200 and see what happens. Appreciate the info. Ill post back after i get the weight jacks/konis on. Ill be putting my order in for the SFC also.
Thanks for the orders and the upcoming SFC's!
I've always been of the opinion that quick ratio is my preference. We used "as quick as possible" on our oval track cars and I've also upgraded my street cars to the quickest applicable box. If your box is stock from the car, you should be able to identify the actual ratio from the huge amount of info on thirdgen. Steering slop is a different story where you can have a desirable ratio but still have play in the system. If you do go quicker, make sure you get a box with fewer miles on it or have the box gone through by a reputable shop.
ramey
You're welcome William. This handling thing is a lifetime learning situation. I still learn every day.
ramey
ramey
Also does UMI offer a steering kit? specifically one that will help with bump steer?
I turned 23 yesterday and for my birthday my girl surprised me with an order of the 22mm rear sway bar from you guys. Will throw it on with the new suspension and see how it effects the handling. Upping the size of the rear sway bar will potentially decrease understeer right?
Thanks for the input ramey. Im looking into the steering rebuild now, and looking for the best ratio box i can. Is there anywhere you suggest i look for a "quick" ratio box?
I wish girls would buy me car parts...
JamesC would know the best ratio box. I'm thinking IROC box? Maybe others who know factory parts better than I do will chime in.
We don't offer a bump steer kit. Actually I've never heard how the 3rd Gen suspension is for bump steer...
Wow, I'm 0 for 2 in this thread.
I do know the sway the sway bar answer. The 22mm rear bar helps the car rotate and does indeed decrease understeer. It takes the Push out of it.
Thanks for the sway bar order, by the way.
ramey
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you can piece together a bump steer kit for a reasonabe amount. However, do you need it? From personal experience, the bumpsteer is not bad on these cars, and at stock height or lowered pretty far, i have not seen an issue in this department flare up.
That said, once umi comes through with new shiny parts..... and i can get the front end back together, i was going to mess around and see what kind of bump steer i have and what i can do with it.
Hi William.
ramey
ramey
And yeah its kind of nice, but when your only two interests are her and cars/driving it makes gift shopping a little difficult lol.
Ill PM JamesC about the gearbox or ill try searching more first.
As for the bump steer, it was pretty bad when i first got the car. Since then ive replaced the ball joints(moog) and got the CC plates with a good alignment, which as helped a lot. I dont notice it much now, but every once in awhile i can feel it.
Might be from the slight play i have in the steering though(think from the gear box). Best to replace the gearbox and other steering components then address it if its still there i guess.
03-26-2012 08:30 PM
//<86TA>\\ you can piece together a bump steer kit for a reasonabe amount. However, do you need it? From personal experience, the bumpsteer is not bad on these cars, and at stock height or lowered pretty far, i have not seen an issue in this department flare up.
From what experience i have which isnt much, its no joke. One of those things that can put you into a wall of a canyon or guard rail if its too severe or sudden.
Car: 89 Iroc
Engine: 305TPI
I have a post out there on the bump steer kit. I pieced it together, with the help of //<86TA>\\. Speedway Motors has all of the parts you need and depending the route you go for the hiem joints, you can get by for right around $100. I went with the high end joints and some dust covers and was right at $115, which is $40 less than Spohn.
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Bumpsteer put my into a ditch once...Had a silverado pull me out and I just kept on moving. I would go with a brand new steering box if possible, used IROC boxes aren't always good, I test drove an IROC when I was looking for my car and it was like driving a drunk horse...
Car: 1989 Pontiac Trans Am GTA
Engine: 2001 ls1
Transmission: built 4l60e with stall
Axle/Gears: 4:10
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
As far as bump steer, make sure your idler arm is adjusted properly. The frame holes are slotted to allow up/down movement of the arm. A level center link is typical, but depending on your setup you might tweak things to be perfect. The only way to check this is do run the fronts through full suspension travel with everything hooked up, and check toe while changing vertical position. It's a bear to o correctly, but if, once you have your suspension setup finalized, you notice an issue, it's worth checking out.
That said, on a suspension that uses stock pickup points where ride height hasn't been changed a lot (2+ inches), I'd level the center link, and the bump steer is the last thing I'd check...
I just ordered my GC weight jacks with the spring rates of 850/200. I was wondering how difficult the install was? Has anyone ever done it, and have any tips? anxious to get these and the Konis on, as well as order my SFC's this friday if all goes well.
Another update i finally got that Panhard bar on i ordered from UMI. Was a real pain. The bolts seized to the bushing sleeves so we had to cut them out with a grinding wheel. Took 4 blades and I think i have rubber stuck to my arms haha. Worth it though, the rear end is finally aligned and the UMI bar is great quality and easy to adjust.
Installing the rear sway bar this week if it doesnt rain, ill take pics of it all then.
Things are coming along nicely.
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Just found this thread. Did you get your steering slop fixed?
84 TA NV
Sep 6, 2015 08:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
