Is this how my steering column is supposed to look?
My steering column is looking a bit rough. The steering wheel moves in and out about 2 inches right now and the boot on the column looks pretty haggard. As we're doing endurance racing, steering is pretty important. Can I replace that boot and relube the joint? Can I get it to stop moving around?
https://i.imgur.com/Ik9j3.jpg
https://i.imgur.com/M4Pn2.jpg
(links since they're huge pictures)
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Is this how my steering column is supposed to look?
https://www.thirdgen.org/forums/susp...ing-shaft.html
JamesC
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Yes that bushing is suppose to go up into the housing that is sticking out of the firewall and then a retaining clip that I do not see keeps it in place. That fix should take care of most of your problems.
That's kind of what I figured. Whoever did the racing wheel install made it so that it's easy to push the wheel in, so I imagine during racing, a little clip isn't going to hold us from pushing in during hard braking. Is there a relatively easy way to fix the torn boot and keep that joint lubricated? I'll take a closer look at it with the team next friday and see what we can do.
Thanks for the replies!
Engine: 454-350
Now that I look at it again your spring clip is right there on the upper piece of steering column. I just come in from the shop and I have been changing my steering gear. My 83 does not have that boot. A good investment for you would be a manual for your year of machine.
