Sway bar ?
Old Feb 7, 2012 | 09:35 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Sway bar ?
I just bought a WS6 sway bar it is a 36mm but a friend of mine has a Iroc with the 1LE it is also a 36mm I was told they are the same but the one I just got is different
Old Feb 7, 2012 | 10:11 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: Sway bar ?
How is it different? Any pics?
Old Feb 7, 2012 | 10:22 PM
Re: Sway bar ?
..... and ..... ??
Old Feb 8, 2012 | 07:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Sway bar ?
All OE 36mm front sway bars are the same.
JamesC
Old Feb 9, 2012 | 09:31 PM
Engine: LQ4 ls 6.0
Re: Sway bar ?
mine has a bow in the center the 1LE that my buddy has is straight
Old Feb 9, 2012 | 09:35 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: Sway bar ?
both 36 mm i have are bowed, one off a 89 WS6 GTA and one off a 91 z28
Old Feb 9, 2012 | 10:00 PM
Re: Sway bar ?
¿¿..... and ..... ??
This matters because .... ??
What are you REALLY trying to ask? What is the purpose toward which you would put this information to use? Perhaps if we knew how or why it was important to you we could tell you something .... significant. Or, maybe not. It all depends.
If I was the guessing kind, I'd guess that the bowed ones were designed to fit some feature on some cars in some years that didn't exist on other cars or in other years, that the straight ones interfered with.
Old Feb 9, 2012 | 10:04 PM
Engine: LQ4 ls 6.0
Re: Sway bar ?
I was asking to make sure it was going to fit right mine is a 91 and this came off a 89 just didnt wont to have any problems when I install it
Old Feb 10, 2012 | 07:02 AM
Re: Sway bar ?
Well that's easy enough then... there shouldn't be any problems, but if the 2 cars happen to differ in whatever the particular feature is, there could be.
The main thing that might cause trouble is probably the fan shroud or mounting. You can compare the volume that the bar has to go through before you put it on, just sort of eyeball in between the bushings, and make sure the bend doesn't interfere with that, and be pretty sure nothing else will either.
Old Feb 10, 2012 | 07:13 AM
JamesC's Avatar
Re: Sway bar ?
Mine is bowed. Several sets that I've sold were bowed. Since I've never read anything on the web or in my Parts & Illustration Cat. about differences in the OE 36 mm bar, I'd be very interested to learn otherwise. BTW, the single GM part number for the 36 mm is 14094344.
JamesC
Old Feb 10, 2012 | 10:03 PM
Engine: LQ4 ls 6.0
Re: Sway bar ?
JamesC
Thanks I bought it now all I need is bushing
Old Feb 12, 2012 | 11:38 AM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Re: Sway bar ?
Mine is bowed btw. Looks just like yours.
Didn't even know they made a straight one, but it makes no difference either way. If the endlink mounting holes and the bushing surfaces were the same distance apart I wouldn't even bother thinking about it.
Old Feb 12, 2012 | 11:42 AM
JamesC's Avatar
Re: Sway bar ?
Originally Posted by Dizturbed One
Didn't even know they made a straight one....
Probably after market.
JamesC
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
