My Custom Strut Tower Brace
Car: '84 Camaro - 2010 Surf Blue
Engine: 305 - 4 bbl Holley
Transmission: WC T5
Axle/Gears: 3.08
I wanted to get some comments on the STB that I designed and my fab shop at work made recently. Let me know what you think.
Transmission: WC T5
Axle/Gears: 3.08
Re: My Custom Strut Tower Brace
1.75 x 1.25 heavy wall aluminum tubing with solid machined end fittings. The tube was compression bent for a slight curvature to rise over the upper radiator hose before welding the fittings on. The fabricator ground the welds smooth and then polished it.
Very nice indeed
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
clean looking.
and like a few guys will/going to ask. how much to make a few for sale.
I my self. dont see any thing in the aftermarket. That I like.or will fit over my intake when done.
Engine: Cammed 6.0L LSX
That's pretty slick looking, any plans to make more of them?
Car: 1983 Z28
Engine: Forged 355
Wow that is sick looking! Excellent job, this is 10 times better than what I planned on seeing. I myself am really wanting to pull the welder out and will fab one up myself. I really don't know what would be the best material, and I also want it to clear my dual snorkel intake which might be hard.
Transmission: WC T5
Axle/Gears: 3.08
Thanks for all the great comments. Here are some answers to the questions:
jlarsson: pictures attached of the mounting - the bracket utilizes 2 existing bolts of the upper strut mount and one new hole is drilled.
nosajwols: The 1/4" steel brackets weigh 1.5 lbs ea and the aluminum bar weighs 3.5 lbs for a total of 6.5 lbs.
articwhiteZ: I haven't seen anything I really liked either and almost all of them won"t clear a carb w/14" air cleaner. The bracket has 10 deg forward angle which along with the bar curvature, easily clears my air cleaner by 3/4" and the radiator hose below it by 1.5".
Regarding making more of them . . . sorry, but I'm a machine designer by trade, not a fabricator. My friends at work made this for me because they are also custom car enthusiasts. That said, I would be happy to share fully dimensioned drawings with anyone who would like to build one for their personal use.
I am also near completion on a new two peice machined aluminum power steering pump bracket. It's for the metric resevoir/pump unit that was stock on my '84 305. It has a front mounted pivot bracket and a rear adjustable clamp strap. It doesn't use the outer header bolt like the original one does. I really hated the original wrap around steel one and I don't like any of the aftermarket ones either, they just seem too complicated and expensive. I would share drawings of this as well when I'm done if anyone would like a set.
If you are interested in the drawings just PM me and I will send you PDF drawings of the part details.
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
that looks great. a lot of time and thought went into that.
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
That's a nice looking piece rockstarr. What sort of money do you have in that STB and are you going to have more made?
Car: 89 iroc
Transmission: wct5
Sorry, I missed that, my web page is set up on the blue background and I couldn't see the black script.
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
I am also near completion on a new two piece machined aluminum power steering pump bracket. It's for the metric reservoir/pump unit that was stock on my '84 305. It has a front mounted pivot bracket and a rear adjustable clamp strap. It doesn't use the outer header bolt like the original one does. I really hated the original wrap around steel one and I don't like any of the aftermarket ones either, they just seem too complicated and expensive. I would share drawings of this as well when I'm done if anyone would like a set.
Great STB, btw. Mike.
tcflint
Sep 27, 2015 05:58 PM
