Steering gear box question (videos)
Old Mar 18, 2012 | 02:19 PM
Steven6282's Avatar
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
So while working on my car this weekend, I was trying to figure out the problem with the play in the steering. I'm pretty sure it's all in the gear box now, if anyone wants to confirm watching these two videos. I've tried tightening the adjustments on the steering gear box and these videos are after doing that.
This first one is a video of my rag joint (which is in pretty good shape from the looks of it). You can see the play in the steering wheel initially as I rock the wheel back and forth, and it looks like it's turning the steering gear box shaft when doing that, I also turn the wheel fully to make the wheels actually turn and then go back to just rocking it to show the difference.
Rag joint video
And this video shows the pitman arm while doing the same thing. No movement in the pitman arm while rocking the steering wheel. So I'm guessing this is just showing that the gear box itself is where the play is?
Pitman video
Old Mar 21, 2012 | 09:56 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Steering gear box question (videos)
Can you upload these vids to youtube i can't seem to view them?
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
