steering problem after replacing front control arm bushings
Old Mar 20, 2012 | 12:52 AM
darion45405's Avatar
so i just finished replacing the driver side control arm bushings and ball joint. after finally getting it on the ground (springs are not fun). when i took it out for a test drive drive i noticed it felt "weird" when i turned left. there is resistance when i first start the turn, but not through the complete revolution of the wheel. it does not matter what position the wheel is when i start turning left i feel resistance. but it turns right perfectly. has anyone else had this problem after replacing these parts.
Old Mar 20, 2012 | 01:12 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Re: steering problem after replacing front control arm bushings
Needs a wheel alignment.
Old Mar 20, 2012 | 06:03 AM
Did you grease the BJ?
Watch the steering linkage and make sure you haven't got something out of place and the linkage hanging up on something.
Old Mar 20, 2012 | 11:06 PM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
You only did one side so their might be an imbalance causing binding.
Old Mar 21, 2012 | 01:06 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
ALWAYS do both sides. You don't replace 1 shock or one brake pad...
Old Mar 21, 2012 | 01:15 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
+1
Old Mar 21, 2012 | 04:49 PM
i do plan on doing the other side then i know it needs an alignment. if i still have a problem after replacing other side and alignment i will go from there. thanks for replies.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 25, 2015 07:34 PM
